I bought this bike only a few days ago and have ridden it three times on short shake down runs only. I've been using it set at maximum assist 5 for the moment to get used to cycling again. I've only gone a bit less than 10 miles each time and the battery indicator has been showing one light out when I get back. I put it on charge then and it has taken about four hours or so to charge up.
But today I went through the lanes near my house and back on an A road; not very hilly but some short steep hills which I used to have no trouble with when I had my last MB five years ago. The main road is a long fairly shallow climb for about two miles with a short downhill between, then leveling off and going down into a village after nearly a mile. About 10 miles into the ride I noticed a slight loss of power going up the last uphill before the run down to the village, and on the way down the power went completely.
The battery was showing just one light and the display was dead. I tried leaving it a minute or so but it lit the display up briefly before it died again. So I pedaled it without power most of the way up a hill which I used to go up easily in second gear on my old bike, and it was hard work with the weight of this one. Then after a bit I had a rest and tried the battery indicator again, and it was now showing two lights. So I rode it up the rest of the hill and down the other side to home at level 3 taking it easy.
When I got back all the lights except one were lit like the other times I ridden it about 10 miles. The brakes weren't binding, the tyres were at 65 psi, so what was going on? I put it on charge when I got back and the charger went green after just over two hours? Which doesn't seem very long.
Does it seem like a battery issue? A charger issue? Or did it cut out from an overload? Which seems unlikely given that it was going downhill at the time. It can't be just running out after 10 miles surely? It wasn't even that hilly where I went.
