What you get:-The Magicshine MJ-818 is one of the brightest rear lights on the market its as bright as a car break light! The is a 3 Watt LED in the centre and 9 SMD Red LEDs around it giving 85 Lumens of red light.
The lighting mode can be changed by rotating the metal bezel that runs round the outside of the light. It scrolls through the following sequence:-
Mode 1 All flashing,
Mode 2 Center LED Flashing then 9 LEDs flashing internittently
Mode 3 Constant Light, all LEDs on.
The lamp can be installed in less than a minute using the rubber 'O' rings which are very secure and accommodate both standard and oversized seatposts. The lamp unit can also be mounted to a helmet mount or headstrap.
The lamp can be run off any magicshine battery pack using a Y piece to give an extra light connection point and an 100cm extension to run power to the back of the bike. The Lamp can also be run off its own battery pack which can be secured to the frame using strong velcro straps on the battery bag. Fitting takes takes literally seconds.
TECHNICAL SPECIFICATION
Super bright 85 lumen manufacturer rated output
3W red LED + 9 SMD red LEDs
50,000 hour average LED life span
IP64 Weatherproof rating
Constant mode and two flashing modes.
Anodised, anti-abrasive, aircraft aluminium
High temperature protection circuit
Approx. 75g fitted
Magicshine rear lamp complete with battery lead (Y splitter).
'O' ring for fixing the lamp to the bike's seat post.
Just add to your existing Magic Shine (inc clones) front light or buy a seperate battery - avail on ebay from £20.
I am selling for £25 inc postage to anywhere on the UK mainland.
