new to cycling
ladyellie
Oct 5, 2017
64
bradford
Hi im new to cycling and also forums. i have a whisper 86 torque, folding bike. i found this forum pedelecs while searching for a error 30 problem which happened when i stopped at the top of a hill. Does anyone know why this is happening? is this the right sight for what i need? only just getting into electric cycling.
LeighPing
2,547
1,945
The Red Ditch
Might be worth giving them a call on that number above. But, if you check back here later, someone might know more about your error code.
Error code 30 is communication between the controller and display not working properly. There's lot's of different causes, though not much you can do to influence any of them. it would be best to discuss a remedy with Wisper directly. They'll sort you out.
8,593
Error 30 comms abnormal, the fault is as mentioned above caused by a faulty;
Contoller.
Lcd .
Main trunk cable.
If the fault isn't a trunk cable issue then comms data is supplied back and forward via the Rx & Tx lines so would suspect a controller issue.
Wisper Bikes
6,288
2,254
69
Sevenoaks Kent
Thanks, I am please yiu like the bike, it’s one of our best sellers. We are not open on Saturdays but will be in on Monday.
Have a great weekend.
Kind regards David
