October 22, 20214 yr I have an e-road bike (Cannondale neoSynpase2) , but I also fancy an e-mtn bike and would like some advice as to what to buy/research. I'm 73 and weigh 94kg; I would not want anything too 'technical' -my days of skiing black and red runs are over. I just need something that would be adequate for bumpy mountain trails -and must be 'comfortable'. What would really swing it for me is that I could use the same battery as on my Cannondale. Any ideas/advice gratefully received. Thanks
October 22, 20214 yr you wont be able to use the batt with anything else as imo it uses can bus and a locked system.
October 22, 20214 yr I have an e-road bike (Cannondale neoSynpase2) , but I also fancy an e-mtn bike and would like some advice as to what to buy/research. I'm 73 and weigh 94kg; I would not want anything too 'technical' -my days of skiing black and red runs are over. I just need something that would be adequate for bumpy mountain trails -and must be 'comfortable'. What would really swing it for me is that I could use the same battery as on my Cannondale. Any ideas/advice gratefully received. Thanks Does your Cannondale use a Bosch Powertube 500w battery? If so, that'll fit other Bosch Powertube 500w bikes. Try looking at the Cube e-MTBs
October 22, 20214 yr Author Does your Cannondale use a Bosch Powertube 500w battery? If so, that'll fit other Bosch Powertube 500w bikes. Try looking at the Cube e-MTBs Hi, thanks, will do.
October 22, 20214 yr you can also get a adaptor so a 500w batt will fit a 650w frame thought it was there old hub motor lol
