New light
gray198
1,592
1,069
My Freego Eagle has a front light fitted and connected to the battery. It is not very good so I was wondering if I could replace it still using the available wiring. Any ideas what to get
gray
IR772
931
1,044
Leominster
Well this would work, but it is expensive.
http://www.ebay.co.uk/itm/DURITE-CREE-LED-25-WATT-9-36-VOLT-SPOT-LIGHT-LAMP-1700-LUMENS-0-420-55/262595414876?_trksid=p2047675.c100005.m1851&_trkparms=aid=222007&algo=SIC.MBE&ao=2&asc=38661&meid=ea07382c61ca4eaca3240df5dd643e0e&pid=100005&rk=3&rkt=5&sd=262595459480
Durite make a range of motorcycle lights. So it might be worth visiting a motorbike dealer and having a look first.
The specs are a bit misleading as to it being 25 watts but only draws just over half an amp at 12 volts. So it will be bright, 6-9 watts LED output is good.
It's a lot of money.
Reactions: LeighPing
6,510
100w leds are next ;)
6,510
