new front q100H 260rpm
cwah
3,048
179
www.whatonlondon.co.uk
Raboa
778
294
52
The standard Q100 can run at 18 amps, so the Q100H should manage 20A, although I've not heard confirmation of that. I'd stick to 36v, though.
Elecman
65
Hi, have you still got any of these left ?
I have a 36v 10ah battery on my other bike, would this work OK with this motor ?
What would be a good controller to push this motor ? (I only tend to do 15 mile journeys so not too concerned about battery life.
Sorry for all the questions !
It'll work with any 36v battery. The controller is a bit more tricky. They generally don't work with sensorless controllers, so you need a high-speed sensor one. The KU65 from BMSBattery should be OK, but there are better ones with LCDs; however, everything keeps changing, so it's not so easy to say which ones will definitely work.
cwah
3,048
179
I confirm it doesn't work well with sensorless controllers. I thought the motor was going to die when I tried it.
I have one left and 2 other Q100H 201RPM laced on 26" wheel for a 2 wheels drive project. But I gave up on it so if you're interested I can send them to you.
eHomer
635
164
Hi,
Is the 260rpm one still available ?
You mentioned "new" but the flange looks a bit scratched in the photo.
Has it been laced into a wheel and then removed ?
thanks,
cwah
3,048
179
There is a front 260 rpm available.
Scratch and dents come from shipping. It has never been used
