Evening
I have bought a e bike conversion kit,all plugs for throttle,lcd,brake leavers and pas plugs match up with each other.Have come to match battery up with the black and red connections on ecu but as in photo connections on battery holder have plugs but on ecu they have a fixed connection which can be put into yellow junction box as in photo.Wanted to ask if its ok to cut those little plugs off and attach the same connection as those coming out of ecu then they will all connect together in little yellow block.
Thank you
Ian
Thank you
Ian
