New donor bike
Anthonyexmouth
253
27
53
Exmouth
Ok, converted my 2004 rockhopper with a 350w BPM rear wheel a while ago and loving it. One gripe is the weight. It was never a light bike to start with but it is bullet proof and info like it. If I wanted to get a new frame can anyone suggest a well specd alternative that would shed a few pounds. Maybe a newer rockhopper? Any ideas would be appreciated with a few good reasons for the choice.
Rick Bullotta
33
9
63
USA
FYI, you'll likely need to swap/change a whole bunch of components when you go to a modern frame from a 2004.
A rockhopper frame is very light. It's all the components on it that make the bike heavy, so update only the components, not the frame:
Hollowtech chainset
Lightweight (hollow) stem and carbon fibre bars
Lightweight pedals
Lightweight tyres
Higher spec forks or rigid CF forks
You can get all those things pretty cheaply from Ebay, especially if you buy used ones.
I bought mine from a Chinese supplier on Ebay - only about £10.
can you recommend any lighter parts that would be a good match for my rockhopper.
You need to say what components are already fitted to your Rockhopper because there's several versions.
I fogot to mention that you can often save a lot of weight from the seat too.
Look for any used Hollowtech crankset. The more expensive, the lighter. You can find LX for about £50 and XT for a bit more.
Just type in light weight pedals and choose whichever take your fancy. Magnesium are lighter and titanium shafts lighter still but more expensive.
For the forks, you have to look up the specs to get the weight, and you have to decide if you want to save weight by going rigid. For Suspension ones, Rockshox Reba.
Your stem looks like a heavy one. You have to look at weights of potential replacements, whuch they normally include in the listing info.
There's loads of cheap CF bars from Chines supliers on Ebay. Take your pick.
Same with seats, you have to look at the listed weights. Again, ones with titanium rails are lighter but more expensive. You can also save a bit of weight on the seat pin if you have a crappy one.
You have to do Google research for your tyres. You need to consider puncture protection and rolling resistance in relation to weight. I guess you can't have all three, but should be able to get a good compromise. Going down on width saves a lot of weight. If you only ride on the road, you don't need fat knobbly MTB tyres.
When you've sorted the main components, look at everything. Get rid of all the accessories that you don't need.
Don't forget that it costs a lot less to save weight from yourself.
Anthonyexmouth
253
27
53
Exmouth
newbie question here, looking on fleabay for cranksets and most seem to say 10 or 11 speed. how does that that make a difference to whats on the rear? ive got a 9 speed
It's only the width. 10-spd is a bit narrower than 9-speed so you can use a narrower chain for a 10/11 speed cassette, but still works with 9-spd.
8,781
Replace BPM with Q128 to save 0.8kg or if you're brave, a Q100 for another 0.8kg off.
Weight saving may be even greater, although I haven't weighed the bpm or Q128. The difference should be 1.3kg given the quoted weights and 2.3 kg for the Q100.
Related Articles
