Need help choosing between these bikes
TheBag
69
I've finally narrowed down my choice of ebikes based on lots of reading and plenty of help from the pedelecs community.
I've significantly raised my budget from under 1000 to around 1500 in order to get a decent bike so if there's any obvious bikes I've missed in this price range, let me know.
The choices are:
Cube Acid Hybrid One 400 29er 2019 - Electric Mountain Bike
Haibike SDURO Cross 1.0 700c 2019 - Electric Hybrid Bike
Oxygen S-CROSS MTB Electric Mountain Bike
905 SE Crossbar
905 Torque Crossbar
Woosh Rio MTB
There are a few various deals on some of these so price differences might not be as big as they look.
To clarify once more, I won't be doing many miles each day, probably close to 3 miles per day now that I think of it, but some steep hills on the journey which I don't want to be sweating buckets when I reach the top.
Who knows, I might actually enjoy cycling and decide to do more than just commute to the train station.
Thanks for any advice you can give.
TheBag
69
the amount of pedaling when you hit the steepest segment of the hill is the same, for a bike with crank drive or hub drive.
If the motor can give at most 500W mechanical power (typical for a bike fitted with 17A controller), then that will be the same either with crank or hub motor.
On a bike with hub motor, you have to maintain a minimum speed of 8mph not to cook the motor, that limits the gradients to about 12%. However, CD motors can leverage on your gears to optimise speed and heat loss.
On a bike with crank motor, you figure out which gear is best for a gradient in seconds, the bike slows down when you shift gear in the wrong direction.
Good to know, so based on this and my journey data I posted, I'm assuming you would also recommend a crank motor rather than a hub?
17,018
the elevation is only 90m. Although a small section of it is very steep, it's not much for an e-bike.
I think you would still be better off with the Rio MTB because it suits slow pedallers a lot more.
The Krieger is also due for revision this year.
Reactions: TheBag
TheBag
69
I don't know how fast I'd be pedalling honestly. I'm not in terrible shape, I just haven't cycled for a long time. The rio was in my original list but after all of this discussion, if I actually enjoy cycling and want to do more than just my commute, it seems like getting a crank motor is a little more "future proof".
It sounds like I'm going to want the new Krieger when it comes out, just like when I was originally considering the Karoo, someone from Woosh showed me a screenshot of the new one which comes out this summer and it looked so much nicer but I don't want to wait :(
TheBag
69
Right, I'm going to make a decision tomorrow I think - Want to try and cycle this weekend so if anyone has any other advice they can give me, please let me know
Chris M
111
153
I would have thought a crank motor gives you more chance of being able to pedal in a way that is comfortable for you while getting as much assistance as you want from the motor.
You may well be over-thinking this. I have a Cube Acid allroad with a Bosch Active Line Plus crank drive and it just works very well and I love it; I am sure all ebikers would say the same about their steeds no matter what the set up. Riding mine feels quite natural and like riding a normal bike. I use the gears less than on a normal bike but pedal in the same way. Its just so much easier and you feel like you are much stronger than ever before. Remember you can choose how much assistance you have from the motor so as hills get steeper you can change to a lower gear and increase the motor assistance level.
The thing I love about an ebike is that you know you will always have enough energy to get to where you are going, unless you forgot to charge the battery.
Reactions: TheBag
8,621
Torque drive crank (or hub but not many) are ok if you have the fitness or stamina.
If you get tired then your job is made that much harder esp if you like to ride longer distance of 60-100 miles.
Reactions: TheBag
TheBag
69
Amoto65
807
502
Cheshire
I think if you can narrow it down to a local dealer who has one of these in stock, just in case of any problems, then you have nailed it....
TheBag
69
I was just going to order one online... if worst comes to worst, i will travel a bit of distance to get it fixed if it breaks but i expect I will be able to fix most things myself. Despite my novice knowledge of some specific details of bicycle physics, I do have a kind of engineering background from a previous life and I generally fix most things myself. There are far fewer and less complicated parts in these bicycles than there are in some of the other things I've fixed or built over the years.
TheBag
69
If the motor fails and is still under warranty, I will just take it somewhere to be fixed under the warranty. Maybe I'm being a bit naive but as I live so close to London and also am very accessible to other areas being almost on the M25, I'm not too worried finding somewhere to get a big name manufactured bike fixed. Don't worry about embarrassing me - please tell me if it's foolish.
TheBag
69
More than anything, I don't really have the time for at least a few months. I have no free weekends until mid July and work fairly long hours with a young baby at home. I'll happily sacrifice a little overall satisfaction and even money for the convenience of ordering one online and getting to use it for the upcoming summer months.
It's part of the reason the community here is so valuable to me for helping me make a decision although I fully accept that there is personal preference involved. I actually have a decent gap today for lunch so I might see if I can get to a bike shop and if I can't test some bikes out, I can at least talk through some details and see them in person.
8,621
Bosch dealers are not one for all franchise stop shop and won't instigate a repair if you not buy your bike from them without charging you for labour minimum.
Reactions: TheBag
Chris M
111
153
I really like the 29er wheels on my Acid. I didn’t think larger wheels would make much noticeable difference but going from a 26in to a 29er was quite a revolation. Much more stable and comfortable. The tyres are fine both on and off road. They probably have more rolling resistance on the road than a 700 because the 29ers are wider but with the motor that doesn’t matter. They will almost certainly be better than a 700 on trails. The 700c and 29er wheels are the same diameter but usually 29er tyres are wider than 700s
  • Useful
Reactions: TheBag
TheBag
69
again, maybe I'm just being naive here but surely if the bosch motor fails and it's under warranty, they have an obligation to fix it for free? Are you saying that they may charge to remove it from the bike to diagnose, fix or replace the part?
TheBag
69
I looked at a couple of bikes at a really good boutique store near oxford circus at lunch time today. I didn't have time to test any but discussed a whole bunch of options and aside from still being set on a mid drive motor, I really like the look of the haibikes and learned a little about the different bosch motors at the same time.
What is the general view on buying last years models?
I saw this bike https://www.leisurewheels.co.uk/m12b0s184p19822/CUBE-Cross-Hybrid-Pro-400-2018 which has a "Bosch Drive Unit Performance CX (75Nm) Cruise (250Watt)" motor and looks better than pretty much everything else I have seen at that price (I have found one available for £1350).
How do you think this compares to the similar Haibikes, Cubes in this price range?
6,596
you will pay more for haibike but it really comes down to the spec of all the other parts put together overall you will get more for ur money with cube than a haibike.
