Need a light electric bike for below £1000
tapash
166
13
I am thinking of buying an electric bike but so much confused by the choice of variety. Also do not have enough knowledge of it.
I need a bike that is as light as possible, because I need to carry it on stairs for 2 floors.
Also need a good battery, at least 25-35 miles range.
I have narrowed down to 2
Green edge cs2 -19kg with battery
Expedition-20.5 kg
Does anyone have a better option or opinion about the above 2? Or a Lighter one maybe?
Can also consider folding ones if meets the criteria..
tapash
166
13
Thanks, I actually went to a shop in London and tried A2B folding one. Didn't like so much. Feels a bit flimsy. So, I think I will only go for minimum 26" wheel.
Now I was reading personal experience of some cyclist in this forum who bought bikes like Cyclotricity, Bruisch etc. Although they have spent reasonable amount but the quality of component becomes compromised.
I can stretch to 1100£ with weights ~20kg, so, is there a chance i can get a decent bike with good component within this range of price?
You won't get the top quality cycle components in that price bracket, but they can be adequate for the purpose.
Try checking out the Woosh range and the Kudos range.
Also some of the eZee range from Cyclezee are only just above your budget with one below, and they have some above average components in this price bracket.
Also from Cyclezee some of the Ansmann range are within your price bracket and as German made e-bikes are the usual better German build quality. They also have industry leading long warranty periods.
tapash
166
13
Thanks!!
Woosh Zypher-b seems good one, but weight of all theses bikes are 22Kg+, which would be difficult for me to carry up -down the stairs. I was expecting something like 15-16kg, but that seems very unlikely.
Re:Ansmann range, how do the warranty works? do i need to send to Germany in case of faults?
trex
7,703
2,671
Thanks!!
that's easy, use the throttle to pull bike, you and shopping up the stairs.
woosh have a lovely lightweight test bike with Magura hydraulic brakes, 17kgs all in, in their workshop gathering dust. They may sell it to you cheap.
No, the Ansmann warranty is operated by their UK agents Cyclezee, but a return would have to be to their base at Milton Keynes. That's unlikely to be necessary though, there are few problems and most can be sorted either through a local bike shop with e-bike experience, or with help from this forum.
If you are not too distant from Milton Keynes you might also get personal atttention from Cyclezee.
Very few e-bikes are much below 20 kilos, it's difficult to achieve lower at moderate prices. I wouldn't like to climb stairs with any of them to be frank.
tapash
166
13
Which bike are you referring to? do you have a link for that please?
trex
7,703
2,671
I've got a picture somewhere. Will post when I find it. The bike is an ultralight frame 700C with normal bottle battery.
The main thing is it has Magura HS11 or HS33, I can't remember, front and rear to save weight compared to hydraulic discs.
tapash
166
13
So How can I get it? directly on their website I don't see anything like that...!!
C
Cyclezee
Hi Tapash,
With regard to your question about Ansmann bikes, as has already been mentioned by Flecc, we can deal with any warranty issues right here in the UK.
So far we have not had a single warranty claim for an Ansmann bike or kit, the only part we have had to replace was cable from the handle bar display which was accidentally damaged and we replaced it free of charge.
As for the eZee bikes and kits, we hold most parts in stock, any that we don't can be shipped by airfreight from Shanghai in one week.
Kudoscycles
Official Trade Member
Apr 15, 2011
5,566
5,048
www.kudoscycles.com
The Kudos Tornado is 21kg,that's about as light as it's possible to get and still have a powerful motor and reasonable range. The battery detaches easily so you could take that off before carrying the bike up the stairs.
There are many Tornado owners on this forum.
The Freego Raptor is very light but the range is very reduced.
KudosDave
tapash
166
13
Hi Tapash,
Thanks, Do you have any Ansmann that is below 20 -21kg? (incl battery). I have noticed, in your website no bike has stated their weight!!
tapash
166
13
KudosDave
I have actually thought of freego Raptor but even with double battery the range can be justified and still it remains below 15kg. What is the cons of Raptor?
Another option I have looked at is Oxygen, looks really cool, with good components and features. and range is 50miles. Although price is a bit out of my reach.
JohnCade
1,486
736
Take stated range with a pinch of salt on all these bikes. Range will be how much you use the power, and how hilly it is where you cycle, and how fast you go. A large part of the weight is the battery, and the bigger it is the more range you have, and also the heavier the bike is. You can take the battery off and carry it upstairs separately. The bike would be a lot lighter like that.
Reactions: trex
C
Cyclezee
Hi Tapash,
The Ansmann FT-15 with 53 cm frame for example weighs 22Kg 'fully clothed' i.e. including battery, mudguards, lights, suspension seatpost. It has 27 speed Shimano Alivo Derailleur gears, 700c wheels, Schwalbe Energizer tyres.
If you stripped it down to the component level of some of the other bikes that you are considering, it would be within weight range that you are looking at.
The unmatched warranty weighs nothing.
Alan103
12
Expedition-20.5 kg
Hi there, I'm in pretty much the same position you are in and can't decide what to buy but have came across a few bikes that I am considering, the Woosh Sirocco Sport (CD or TS) both - 21kg, the Burisch Synergy GT250 - 20.5kg.
trex
7,703
2,671
The Sport TS is about the same weight as the Burisch, the Sport CD is about 1kg heavier than the other two.
