As the title says, it came this morning.
I couldn't wait to get it unpacked from it's very safe and secure packing with loads of velcro straps to hold everything safely.
Checking the battery it was nearly fully charged so after checking it over, and finding almost nothing to do as it was all pretty much set up perfectly and ready to go, I set off on its first ride out.
Pulling away at junctions was a breeze, touching the throttle to get away then on assist 5 peddling away and I'm at 18 mph before I know it under my own steam, as the assist stopped at 15.
Slowing into a nice easy pedal rate a very noticeable surge of help kicked in again, and I was happy to cycle along with assist enjoying the ride.
Everything worked well, the hydraulic front and rear brakes were great, the saddle that has a spring mounted post was very nice.
The gears were fine once I got used to them, as it only needs a small nudge to change gears of which I found the seven just about right. At first I was pushing too far and going through a couple of gears at once, but I soon got used to being more gentle on the pushing of the lever.
I only did seven miles as it was just a get the feel of it run out, and the weather looked bad and it started spitting so I headed for home.
My first impression is it's great, the sitting position is shorter than I'm used to being stretched out over a touring frame, but I'll get used to the more upright position in no time.
I can't wait for the next ride out, which is hopefully tomorrow weather permitting.
Would i recommend this bike? Yes with out doubt, its a great comfortable ride with the seat post and suspension forks and thanks to the 17 ah battery I'm looking forward to some nice long days out on it.
