My journey so far
Carl South West UK
Sep 10, 2016
Cornwall
Hi everyone.
I'm so glad this group exists as its been a very confusing time of late, and I have had more than one sleepless night thinking about bikes!
I have always loved cycling but a dodgy hip joint put an end to my cycling (I couldn't even get my leg over the crossbar to ride). But last year I had a ceramic hip joint fitted, and now the job is a good one. But my fallen foot arches are now giving me grief. So another operation is needed to fuse the bone together and give me a more pain free foot. So you can see where my cycling needs are going.
I used to see an early electric bike being ridden, with its big plastic box of batteries and think - no way. next thing will be an electric scooter, and then a wheel chair. I'm not ready for that!
But I have recently noticed a new wave of bikes that actually look pretty good, really good in fact. But when I started looking I was overwhelmed by what was available, and also the prices.
First thought was convert my old Cannondale with a kit. It was recently updated and the parts are in good condition and decent spec. But what I would have is a Killer V900 downhill looking MTB, with a big battery and hub, wires clipped all over the place. I don't think the bike will be right, plus cost and time wise I may as well spend a little more and buy a new bike. But which one.
With a one thousand pounds budget, the marketplace is like a minefield. But the one thing that stands out in this bracket is weight. It seems to have been brushed aside as par for the course. E bikes are heavy, end of. The motor compensates for the extra weight, but if you don't want to use the motor, say on a flat road. You are then carrying the extra weight, so you need the motor. Its kind of a vicious circle.
I'm happy to propel the bike along, I just want some help on hills, so as not to put too much strain on my joints and then to have the power in reserve if I need it. So a torque sensing bike might be better, but my present understanding is that torque sensor bikes are more expensive.
So the search goes on.
If you only want help on hills, a torque sensor doesn't offer any advantage. A simple switch would be enough.
An electric bike doesn't need to be heavy. Ready-made ones start from about 16kg, or you can convert a light bike to electric at less than 14kg.
Perhaps it would be a good idea to tell us what you've got and more about what you want rather than telling us what's wrong with some electric bikes, then perhaps we can help you.
Reactions: LeighPing
D8ve
2,142
1,294
Bristol
On the flat weight doesn't really make a lot of difference. Once you are at speed its cross sectional area and wind resistance.
It's only uphill it counts, and being electric uphill is easy( for a certain value of easy)
If you already have a bike then a conversion will cost a lot less than a grand.
Basic minimum spec should be disk brakes, 36 volt and better than 10 ah battery. The bigger the battery the better, mines 16ah and gives massive range.
Angelnorth
209
170
Hexham, Northumberland
^ this
I suspect it's worth thinking about the gearing as well. I've only started cycling in the last six weeks or so having not been on a bike for around 20 years so I don't have strong cycling legs by any stretch of the imagination but I can pedal past the assistance limit on flat road using the higher gears (6, 7 or 8) on my Wisper. My Dad's Byocycle does have small wheels (20" as oppose to my 26" ones) but the gearing also appears to be much lower, making it difficult to pedal up past the assistance limit.
If my suspicion here is right, I'm sure the more technically savvy guys here will be able to say something useful about numbers of teeth and ratios if you can say more about the kind of terrain you want to use the bike on (hills etc). It might be another pointer that conversion of your existing bike is worth considering though - you'd have the range of gears you're used to, just the option for some extra "oomph" when you feel you need it.
