Hi all,
Thanks to your advice I have finally received my Kudos K16, which is the first e-bike ever owned.
I must say they should have marketed the bike a lot better as it looks so much better than the pictures.
Also it can be fold in two different ways, which was a very pleasant surprise as I was worried about the 'trolley' mode only.
It's lightweight and I have no issue carrying it thanks to the handle on the frame.
I would like your advice on:
How to maintain the bike to ensure it lasts for a long period?
Here some picture of the K16:
- Chain: It's a single speed so I don't have to worry about the gears. II have been told that once a month I should clean the chain and grease it again. I also got WD40, which components should I lube and how often?
- Battery: I have done a full cycle as first charge. I might be looking to only charge 4 out of 5 bars and have a full-cycle once a week or fortnight. I believe this should be correct.
- Tyres: have ordered a bike pump with gauge; I assume every couple days I should check the optimal pressure. Luckily I'll keep the bike in my flat so that shouldn't be an issue.
- V-Brakes: well, have no clue here, don't have a long history with bike before this. Please advise.
- Electric system, wires and cables: as above, no idea.
