Hi all,
I’m about to start an E-bike build. First some stats:-
I’m 84kg
My commute to work is 10.5 miles
The route has a couple of gentle hills
The bike will have 700c wheels with 28mm tyres. I’ll probably be using something like the Charge Grater 3.
For the build I’m thinking about using the following parts:-
Hub motor - Q100H
http://www.bmsbattery.com/front-driving/630-250w350w-q-85100sx-motor-e-bike-kit.html
I’ll be building the motor into a rim that I already have.
Battery, charger, controller and Display meter
http://www.bmsbattery.com/36v/567-bottle-ebike-battery-controller.html
Would I be better to use the S06P or S06S controller?
I assume that I also need a throttle, pedal assist sensor and brake sensor?
I’m new to all this so if anybody has any suggestions, fire away.
I’m 84kg
Hub motor - Q100H
