Motor speed for 16" wheels
Tangsoo
51
59
if a motor rated a 260 or 255 rpm@ 36v was installed in a 16" wheel my calc's say 12.7mph. Spinning the motor up on 48v gives (33% increase) @ 339RPM and 16.9 MPH?
As my ride in to work is pretty constant, very few junctions, some 3 mile straights but one steady climb over 1.4 miles, is it practical/advisable to run a motor at max RPM for longish periods or is it best to go for a faster wound motor at the expense of torque?
Power drops off rapidly once a motor spins faster than 75% of it's maximum RPM.For maximum efficiency, you want it to run also at about 75% of its maximum RPM when at your normal cruising speed. for maximum power, you want it to spin at about 2/3 of its maximum rpm.
The basic calculation for bike speed for a motor is:
Bike speed = 15mph x (motor rpm)/201 x (wheel size)/26 x (nominal battery voltage)/(motor designated voltage) x 1.1
That table gives the actual RPM of the wheel at those speeds, which doesn't correspond with the designated motor RPM because the voltage is normally higher than nominal.
patpatbut
860
79
I have a SWXB clone motor running 340RPM at 36v. The loaded speed is about 17mph (39v nominal) on my brompton.
hope it helps
Pat
Tangsoo
51
59
Thanks for the replies. I have a mac 255 rpm motor (@36v), think it'll be run at 48v. I guess the rub is, is it worth getting laced into a 16" rim? I'd be happy with 15mph, as long as it pulls well on the hills. Undecided about putting it in a F/S mountain bike...
