I have fitted Woosh DWG22C rear hub motor kits to two of my bikes and have been very pleased with the results. The kits use cadence sensing and speed control to modulate the output from the motor. The controller is made by Lishui and the LCD display is a King Meter 529.
Generally, I’m happy with this arrangement, but I’d like a bit more control over the power level settings. There are 5 settings and whilst there are marked differences between Levels 1-3, there is little change if you alter the level between 3-5.
I’d like to make the settings a bit more linear, for example have level 1 set to deliver (say) 40% power, level 5 to provide 100% power with the other levels proportioned equally between these values.
My mechanical knowledge is pretty reasonable, but I have limited expertise in the electronic side of things.
Two questions for the gurus here please:
1) I understand that some displays / controllers allow a degree of user customisation, but I’ve not seen any way to modify the parameters of the King Meter 529. Is this LCD display ‘locked’ or is there any software to permit minor modifications? I’m not interested in changing the fundamental elements such as maximum permitted amps, just the power level settings.
2) Another possibility is to replace the King Meter 529 with one of the ‘better’ King Meter displays such as their SW-U model as this can also display the watts currently used by the motor. Not an essential feature but a ‘nice to have’.
http://www.king-meter.com/backend//KingMeter_upload/material/doc/2020-11-18/SW-U-II User Manual_5S protocol_ V1.0_20201107_1605684849287.pdf
I’m not sure if this display would connect to the existing Julet connectors in the Woosh harness or even if it can be obtained easily in the UK, but might be worth investigating. I have assumed that this display would be able to communicate with the Lishui controller as it is the same manufacturer as the original display.
Any comments / guidance gratefully received.
