That’s the same as mine on the MiRider. Do you know if it works with the Bafang G020 motor ? The Bafang is also a 36v rear hub motor but the controller on my Pinnacle is a pain to operate with gloves and is just a basic LED display.What you're saying doesn't compute. 2020 and 2021 Mirider One use KT LCD5s. Have you modified something or are there different versions? You can see it in the photo in this listing.
2020 MIRIDER ONE ELECTRIC BIKE - ORANGE | Buy an eBike
The new MiRiDER One has been carefully crafted to bring you the ultimate electric folding bike- using a combination of advanced technology, superior style, and quality without compromise. The mid-suspension design perfectly balances weight with simplicity and comfort, all in one sleek, modern...www.buyanebike.com
The LCD works with the controller (KT controllers only, not Bafang). It doesn't have a clue, nor does it care about what motor you have. It's the controller that connects to the motor. if your motor has the 9 pin connector, in principle, you can use just about any controller with its matching control panel.That’s the same as mine on the MiRider. Do you know if it works with the Bafang G020 motor ? The Bafang is also a 36v rear hub motor but the controller on my Pinnacle is a pain to operate with gloves and is just a basic LED display.
Can you derestricted in any wayThe LCD works with the controller (KT controllers only, not Bafang). It doesn't have a clue, nor does it care about what motor you have. It's the controller that connects to the motor. if your motor has the 9 pin connector, in principle, you can use just about any controller with its matching control panel.
KT mmake a range of LCD control panels, which are all compatible with their controllers. The LCD5 is towards the bottom of the range. Most people go for the LCD3 or LCD8. This is the middle page of 3:
LCD Display Meter--Suzhou Kunteng Electronics Co.,Ltd--Suzhou Kunteng Electronics Co.,Ltd
Suzhou Kunteng Electronics Co.,Ltdwww.szktdz.com
What type of PAS does that bike have?
All e-bikes can be derestricted. The Mirider has a KT controller. The Mirider guy said that it had special software init. If that software locks the speed limit, yo can replace the LCD with one that isn't locked.Can you derestricted in any way
