Measuring a bottom bracket
blokefromstoke
31
stoke-on-trent
Did a quick search so hopefully this isn't a repeat thread. Can anyone tell me how to properly measure a bottom bracket? I have my dads old Raleigh 3speed sit up and beg bike. I was looking at converting it to an ebike as its bullet proof and comfy so should make a good commuter. When measuring the bottom bracket its 71mm without the cup(think that's what its called, bit on the left haha), 75mm with it, and when looking at a bafang mid drive it says no more than 73mm. So i wasn't sure if the bottom bracket was just the tube or the whole thing??
D8ve
2,142
1,294
Bristol
image.jpeg It's the empty tube bit with nothing attached. The BBS replaces everything.
If it was a mm or two out you could even file off a little. I had to remove a bit from inside the bracket as there was a lip fowling the BBS when I did mine. Just visible with the white grease
Reactions: blokefromstoke
