Manual and battery issues
Martinarapley
Feb 18, 2021
Ennis Ireland
Hi I just bought a Pendleton Somerby from Halfords in Ireland. I'm looking for a manual for it. Where can I find one please? How do I remove the battery? Which way do I turn the key on the battery to take it out?
Also I don't understand the lights on the battery. When I turn it on all the lights come on then maybe 3 if I've used it a bit. After it's switched on 5 min or do it goes onto one light.
The lights on the indicator on the haldlebars dont appear to correspond with the lights on the battery.
Thanks for your help.
Martinarapley
Feb 18, 2021
Ennis Ireland
Also there's two ports on the battery one at the rear which appears to be the charging port and another on the side. What's the one on the side for. I haven't taken the cap off as I wasn't sure what it is.
Sturmey
756
394
69
Hi. I bought a pendleton for my daughter back in late 2017 but ended up using it myself for a good while. I have uploaded the manual below but there are some differences/changes, so I can only describe my one.
There are two indications of battery condition. The first is on the 790 handlebar led display. I found that the battery can be over 50% discharged and it still shows all 4 bars when idle. It also varies depending on whether bike is idle or the motor is working hard like going up a hill. But you do get used to it after a while.
The indicators on the battery is more accurate in my case as the battery has 'smart' battery management that counts the electric current flow.
Reactions: Martinarapley
8,843
Side one could be a USB port for phone charging, out put about 0.5a max.
