Do you mean 'derestrict'?Hello. Anyone able to advise on a dongle and or a workaround to restrict a Ribble E bike fitted with the Mahle 30 system. 4 or 5 mph extra would be sufficient. Thank you.
Thank you. I spoke with them at their showroom. I don’t think they want to be involved.Did Ribble know of one ?
Hmm…..how would I do that?try telling it your wheel is 16"?
Why do you think that might be ?Thank you. I spoke with them at their showroom. I don’t think they want to be involved.
Thank you however I don’t need a lecture. Clearly, they cannot be seen to be breaking the law. Next.Why do you think that might be ?
Yes. I know this however that wasn’t my question. If you can’t answer my question then please don’t respond. Seems I've registered onto the wrong site. Don’t concern your self for I won’t be posting again. Now, lecture somebody else.The bike is sold as a pedelec , pedelec = 15.5mph cut off as by law to remain classed as a bicycle and not an unlicenced motor vehicle.
Looks like it.Yes. I know this however that wasn’t my question. If you can’t answer my question then please don’t respond. Seems I've registered onto the wrong site. Don’t concern your self for I won’t be posting again. Now, lecture somebody else.
There's a dongle that goes between the two motor connector halves, which increases the speed by 3mph. It's possible that 18.5 mph is the motor's maximum speed at 36v. IMHO, the only way the dongle can work is by a simple spoof of the speed signal on the white speed signal wire. You can do that yourself if you buy a motor extension cable, cut it down and fix a double flipflop as a pulse frequency divider on the white wire, powered by the red and black hall wires. All wires run straight through except the white. Cost about £10.Hello. Anyone able to advise on a dongle and or a workaround to restrict a Ribble E bike fitted with the Mahle 30 system. 4 or 5 mph extra would be sufficient. Thank you.
Many thanks.There's a dongle that goes between the two motor connector halves, which increases the speed by 3mph. It's possible that 18.5 mph is the motor's maximum speed at 36v. IMHO, the only way the dongle can work is by a simple spoof of the speed signal on the white speed signal wire. You can do that yourself if you buy a motor extension cable, cut it down and fix a double flipflop as a pulse frequency divider on the white wire, powered by the red and black hall wires. All wires run straight through except the white. Cost about £10.
SpeedFun Ghost tuning ebike Mahle Ebikemotion X35 and X35+
SpeedFun Ghost ebike tuning kit increases the assistance above 25 km/h of the Mahle Ebikemotion X35 and X35+ ebike motors. Plug and go kit, with original connectors.www.speedfun.bike
Ha ha. You both need to get a life or get out a bit more.Looks like it.
Don't let the door smack you on the 4r5e on the way out.
Unlicensed illegal de-restricted bikes bring ebiking into disrepute and has the daily mail gammons shouting about taxation,insurance and licences.
An important part of a good forum (or good person to person discussion) is to give all useful information relevant to a question rather than just a direct answer.Yes. I know this however that wasn’t my question. If you can’t answer my question then please don’t respond.
YesSeems I've registered onto the wrong site.
Is that so?Don’t concern your self for I won’t be posting again.
