Magic Pie motor and control gear.
Billy Spencer
Dec 27, 2016
Edinburgh
I have a surplus Magic Pie 3 motor that I have built in built in to a Mavic T217 SUP 700C rim with Schwalbe marathon plus tyre this is the “screw on “ hub and will accept a 7 speed free wheel ( Fitted)
It comes with new twist grip throttle and grips , used but in VGC thumb throttle, two sets of brake levers with motor power off connections, 240/ 110 volt mains charger for 48 volt LiPo battery .
The motor can be adjusted using a USB programming cable to run between 200 watts up to 1Kw from a 48 volt battery. This was built up as a light weight off road bike and performed well until the battery was "removed". The kit is complete with extra's but with no battery, would suit an "experimenter "
Some snaps are here : http://imgur.com/a/dd5wK
There is a review here :
https://electricbikereview.com/golden-motor/magicpie-3/
Looking for £ 100 collected from Edinburgh , will post in the UK at cost but its heavy !
PM me for more info .
Regards Billy
