Hi folks,
A couple of years ago I did a rear hub drive commuter bike conversion, detailed here:
I ended up with a 36v rear hub motor running at 48v thanks to the excellent advice from the forum
Now my biking needs have changed! That bike now has no electric parts, and is currently fitted with a follow-me tandem for pulling my wee one around on her bike. This is exhausting as the coupling weighs a ton, so I'm wondering if I could use my existing kit and fit a front hub motor to use with my battery, controller, etc. It would have to be a front motor as the tandem coupling takes up the rear dropout. I would also want something with a lot less speed than I currently have (no plans to pull my kid along at 25mph!!) but preferably more torque for dragging all that weight uphill. The front forks are alu, so I'd be using a beefy brake-bolt-mounted torque arm (I have plenty of spares left from the original build).
Is this idea possible, and if so can anyone recommend a suitable motor?
Q128C 25mph fast hybrid commuter build/ride report
Executive summary: here's a pic of the more-or-less finished bike: 25mph on the flat @ ~600W, 20kg bike weight. Warning: long post comming up :-) This is mostly a brain dump of everything that I did for my recent build in the hope that it will be useful to somebody else considering the...
www.pedelecs.co.uk
