Looking for Recommendations, please
OldPedaller
42
9
Digging into the massive combined knowledge on this forum, does anyone know of an eBike that meets this spec:
Starting with the Big Ask : Weight at the lower end of the scale - ideally 20 Kg or even less for a size Small
Step-through, Stagger/Trapeze frame Ladies model
Crank drive motor
Minimum 60 Nm output
Minimum 450 Wh battery
I know it's possible there's no such bike. The Specialized SL rang are well within the weight, but the 36 Nm motor isn't
going to cut it, (even allowing for there being less weight to push along).
It's really all about the weight/power. My wife struggles to lift the Kalkhoff/Giant/Cube we've looked at
in the local bike shops (actually physically can't lift some of them off the ground). Although of course with stock generally being low
there may be bikes from these makers that fit the criteria.
Anyway, Any suggestions will be much appreciated and followed up.
