Hi, I'm Tom, this is my first post here.
I've been an all year round motorcyclist for years but quite keen to get some exercise into my daily life. I work in central London and live about 5-6 miles north. In the evenings I need to be able to get back home in good time to collect my son from nursery. I don't want cycling to seem like a chore, particularly in the evenings going slightly uphill. An ebike seems perfect since it will take some of the effort away on the incline.
I went to cycle surgery in camden this weekend and tried 3 bikes
First the Ridgeback e-flight DI2. I got about 100m up the road before I realised the gears were not actually working so I returned it. Then I tried the Ridgeback e-flight sans DI2. I cycled all the way up to hampstead and back and thoroughly enjoyed it except my wrists were sore at the end. I found the Steps system a bit whiney sounding but otherwise it was pretty easy to use. Likewise the alfine 8 speed worked well.
Then I tried the Kalkhoff Connect Pro B9. Immediately I preferred the more upright position. It gave me a much better view of traffic and made turning my head to check for traffic much easier. The Bosch Performance Line system seemed a bit more powerful than the Shimano steps too, particularly torque at lower speeds. I didn't even realise there was a turbo mode till the end and that was amazing. The gears - Shimano Alivio not as crisp as the the Alfine system. I also found the front suspension forks helped give a smoother ride. I can't say I really noticed the extra weight.
Key points for me are:
- solid performance
- comfortable ride
- decent handling ( prefer slight curved handlebar rather than swept back )
- upright position ( adjustable handlebar stem )
- very crisp/reliable gear changes
- low maintenance
- can accept or comes with mudguards and rack for pannier.
- preferably not too fancy looking
Price wise, comfortable up to £3k. Would stretch to £3.5k if there was a very compelling option. I'd rather invest in quality than skimp but don't particularly want to pay for unnecessaries, especially if they come with additional complexity. eg DI2 seems a bit risky.
I'm considering the Kalkhoff Connect Pro B10 , a higher specced version of the B9 with Shimano Deore. I'd like to know what are other similar bikes by other brands I should consider.
From looking online the following seem to be possible options:
- Kalkhoff Connect B10 (bosch, shimano alfine, deore ?kg
- Kalkhoff Connect I10 (although heard various positive/negative comments about impulse)
- Volt pulse X (bafang hub with throttle/ deore/ adjustable handlebars/ 24kg )
- Volt infinity 1 (shimano steps/alfine hub gears/di2/hydraulic breaks/21.6kg)
- Volt connect (shimano steps/deore gears/21g)
- Gazelle CityZen C8 (Bosch, hydraulics, 20kg+battery?, gears not specified)
- Cube Dehli Hybrid 500 (Bosch cx, nuvinci n330)
- Cube Dehli Hybrid 500 Pro (Bosch cx, nuvinci n380 auto)
- Cube touring sl 500 hybrid (bosch cx, shimano xt derailler, xt hydraulics, fixed raised handlebars, 23kg)
- Haibike ?? cant find any with adjustable height handle bars
- Scott E-Sub Tour 2017 Bosch
- KTM Macina style 11 CX5 (bosh cx, shimano xt - looks similar to cube above)
- Moustache Samedi Titanium (bosch, nuvinci, hydraulics, 24kg)
- Moustache Friday (Bosh, deore, hydraulics, 22.9kg)
What else should I consider. What of the above are considered the best?
A few other questions:
1) Hub gears seem appealing for their lower maintenance - but is that actually the case? It seems like you have to get them oil-bathed/serviced every year, is that right?
2) Is derailler preferable to hub gears?
3) If hub, Is nuvinci preferable to alfine. I've seen a lot of comment saying nuvinci is better but much fewer bikes with them.
4) Assuming hub, Is a gates belt drive desirable on an ebike? Or just a headache when it goes wrong? Is a decent chair guard as good as a belt in terms of protecting clothes.
Thanks in advance for any guidance!
Tom
- solid performance
- comfortable ride
- low maintenance
Tom
