looking for conversion expertise
John O'Donovan
Jul 30, 2015
hi
My wife has a Pashley Picador trike needing electic motor conversion as it is getting a little heavy.
Any recommended engineers in Anglia region? (or anywhere)
Cheers
John O'Donovan
8,518
Is Southend any good to you ? Woosh may help.
Reactions: John O'Donovan
Can we see some photos of the rear transmission from the pedals to the axle because there's different versions. I'm thinking that a Cylone kit might be a good solution.
trex
7,703
2,671
A rear hub conversion is out of the question because of the differential.
A front hub conversion is possible, about £450 + labour.
A crank drive conversion is best, but more expensive.
You are well placed - Cyclezee in Milton Keynes or Woosh in Southend.
8,518
If you click on the Q rh top page and type Pashley Trike in the search pane you will see some threads on Pashley trikes.
There is a pic of a Cyclone converted Pashely in one thread which Cyclezee did some work on and there is another thread where Cyclezee ruled out the Picador as being unsuitable for a front hub conversion.
