Looking for affordable commute hybride ebike
Ceci
Sep 24, 2023
Good afternoon,
I'm commuting to my new work place (4miles) and can benefit from the cycle-to-work scheme.
I am looking for an ebike, no more than £1500.
So far, i have been checking Riverside 500E from Decathlon, but annoyingly i have to add a lot of accessories (rear track, mudguards to transport my work laptop and lunch box).
I went to Decathlon twice already and spoke to two salesperson, and I did not find them convincing.
Today i was looking at a Whyte Clifton bike from Evan Cycle but cannot find any reviews.
Any advice on the bikes i found above or any other bikes that would fit my criteria?
I ABSOLUTELY Love riding bikes, i have never tried an e-bike, but I am choosing this option because I don't want to arrive sweaty :D
8,526
Saracen you are still misleading folks with your biased and unknowledgable experience of the mid drive vs hub being better myth.
Both on the front wheel drive being problematic and the use of a hub drive for off road , both are very capable of doing so and can contest to this having done many 1000's of miles in the Surrey Hills/North downs & on the South downs.
I can tell you from experience and from many rides that a front Bpm hub at 44v /20a is a very capable option in the most muddiest off road conditions.
8,526
For a commute bike a mid drive would be the least favourable due to extra maintenance and wear costs, a hub will be far more reliable and relaxing unless one enjoys turning up sweaty.
By all means use a mid driven bike for properv off road or leisure use but otherwise a hub will be ideal.
I have both drive types (actually in all) five drive types and they all work / do the job they are designed for.
Predominantly I use a hub drive for commute & errands/ shopping, Ts mid drive for heavy hauling/ towing (though my tiny G370 hub ) is equall for the job.
For ultra lightweight my friction drive is damn good and only adds 2.5kg to my 10.3kg bike.
Reactions: quackstar84
Peter.Bridge
1,239
569
https://wooshbikes.co.uk/?santana3
or
https://wooshbikes.co.uk/?camino
Or
Tony @Woosh is on the forums and the customer service has a very good reputation
Or
Or
Again David @Wisper Bikes is on the forums and goes above and beyond in terms of customer service
3,124
Good afternoon,
Those bikes are great while they're working. We get no end of people coming on this forum asking about how to deal with some electrical problem; however, all we can do is tell them to go back to where they bought the bike from, which seems to be not a pleasant experience for them.
In that price range, you're much better to stick with ebikes that use standard Chinese parts that you can get from anywhere, which makes repairs and upgrades much easier. Your problem is how to recognise these bikes. There have been some recommended above, or there are loads on Amazon and Ebay.
If you're incapable of servicing or fixing anything, my advice would be to buy whatever you like that's in your local bike shops.
All ebikes need something fixed sooner or later. The battery will last a few years, and you need to be sure that you can get a not too expensive replacement when the time comes, so avoid anything that has a niche or bespoke battery.
Oldie
151
41
Scotland
Many newbies end up tied in knots when all they're looking for is a decent and affordable ebike.
My recommendation, as above, is just to get a bike from someone like Woosh or Wisper and rest easy that you'll have great back-up should the need arise, which it probably won't. There are other trusted dealers too if you want to spend some time searching the forum.
Whilst I have converted 3 bikes (because I like tinkering) I still hanker after another tailor made one (I actually had a couple 10 years ago with no issues).
If your aim is to become an enthusiast then certainly spend a few months on here learning the ropes as members like @saneagle offer amazing advice. It's an addictive hobby.
But, if you just want to get to work reliably, buy from a known ebike retailer.
Reactions: esuark and Woosh
peterjd
213
52
My experience with the Decathlon 500E from the Milton Keynes store (reduced price of £999 last January) was very good eg knowledgeable bike mechanics there. Also I already had all the necessary bits other than mudguards to fit it out as a touring/commuter bike. I am very happy with the outcome (see my previous posts). Good luck with your quest.
8,526
I would echo what has been mostly said and woul duse the services of either Woosh or Wisper both have been in business for many years and are experts in the field of selling EPAC's, both having exempalry CS.
DiggyGun
134
57
England
Mrs DG had a Wisper 705, which developed a fault after the warranty had expired.
All fixed FOC by Rutland Cycles and Wisper. Excellent customer services.
However, her first e-bike was a Cyclotricity Sahara, which I believe uses Chinese parts as mentioned earlier. This was a complete contrast as it kept falling to bits. Terrible bike.
DG…
Reactions: Wisper Bikes
Az.
2,032
900
Plymouth
https://www.houseoffraser.co.uk/brand/whyte/clifton-electric-hybrid-bike-930620?utm_source=rakuten&utm_medium=affiliate&utm_campaign=digidip x deal sites&utm_content=10&utm_term=3274037&ranMID=43869&ranEAID=svunC25memk&ranSiteID=svunC25memk-8E.ez.0tO.59KugK0BjTbA#colcode=93062002
£1159 with "OUTLET20" code
Review:
Reactions: egroover
3,124
The Riverside 500E is known for its affordability and good value for money. However, as you mentioned, you may need to add accessories like a rear rack and mudguards. While these additions are common for many commuters, it's understandable that you may be looking for a more complete package. It's also worth noting that the Decathlon sales experience may not have been satisfactory.
Non-standard electrical parts makes cheap DIY repairs and fault diagnosis tricky. Decathlon don't even list the battery as a spare part for that bike. I always recommend to get a bike with standard Chinese parts if you're buying at the cheap end of the spectrum.
Reactions: flecc and sjpt
3,124
In this case, I recommend viewing this brand E-Bike Coop they help you choose one. With the growing popularity of electric bikes (e-bikes), this shop offers an exciting range of electric bicycles to cater to various preferences and needs. One of the standout features of Electric Bikes Edinburgh is its contribution to sustainable and eco-friendly transportation. E-bikes are known for their ability to reduce carbon emissions and offer a greener alternative to traditional gas-powered vehicles. The shop's commitment to promoting environmentally conscious commuting is commendable.
I looked through their range of bikes. apart from Bromptons with little wheels, all their bikes seem to have crank motors. Why don't they sell any proper e-bikes?
Reactions: flecc and Woosh
chris667
164
108
But like anything, there are good quality parts and their are poor quality parts.
I feel my hub kit from Woosh is excellent quality. Certainly good enough for what I need - daily transport I don't have to think about too much.
I think that it's closer to an old-school moped as opposed to a recreational product like most of the proprietary eBikes seem to be.
Reading many of the horror stories on parts availability for proprietary bikes I am very much reassured I went with something that I can replace. If Whoosh went out of business I would be able to fix my bike. That's reassuring.
Saracen
532
Good afternoon,
Before you consider ANY "E" bikes remember to google MID drive v HUB drive and every time MID drive is best, don't take my word, hills, gears, stability, front hub cal "lose it" on slippery roads, drain covers, bends if not careful.
Reactions: jimriley
