Looking for advice
DX408
Mar 20, 2016
Hi there now you more than likely have had this question many times before, I have looked at some threads but although I found some on the same sort of subject I could not find the info I was after (apologies if I have missed it)
I am looking as a total novice for advice on which bike/ type/ motor etc would suit me.
Due to medical issues which required steroid treatment I have now put quite a lot of weight on and now weigh about 21 stone again due to my issues my fitness level is not good at all, but I want to be able to start riding again especially with my children. I am looking for something that would be able to cope with not only my size but give me a good level of assist or even power the bike with out input from me at all, I would be looking at using it mainly in parks so some surfaced road and dirt tracks obviously this would include hills but nothing particularly large or sustained. Range again nothing massive I would think 20-30 miles fully powered would be more than adequate as I do intend to pedal after all this is about getting fit again with help. Is that distance feasible/ reasonable?
Price is an issue as being a single parent working part time as anyone in this situation will know money is always an issue so seeing some prices of bikes I have looked at made me doubt if this was achievable at all.
Anyway thank you in advance for any help or advice you can give me.
6,492
Kudoscycles
Official Trade Member
Apr 15, 2011
5,566
5,048
www.kudoscycles.com
Hi....we all need to know a bit more info. Will you be intending to climb hills with no pedalling? Do you need a step through? How tall are you?An idea of your budget?
KudosDave
Reactions: JuicyBike
Benjahmin
2,590
1,746
70
West Wales
Hi DX,
Have a look at Woosh Big Bear. It's in diamond frame or step through, has a big hub motor and a 15Ah battery. They say it's for 5'6" and above and for the 'larger framed person'. My wife has a step through and is 5'6" and the saddle could come down more. It gets her around hilly Wales and has even passed a roadie up a hill (much to his embarresment):D
chr4
68
11
49
I think it is worth pointing out that some ebikes are rated for 100kg max rider weight. I would check that before making a decision. While some dealers are still happy to recommend them for heavier cyclists I am not sure where they stand if issues crop up.
Bluelabel and scott have some pretty robust bikes but not cheap. Also with crank drives some effort is always required so I guess not exactly what you are looking for.
JuicyBike
1,671
527
Derbyshire
You simply need to try some bikes at your most local electric bike specialist to begin to narrow down your choice.
Any thing else at this stage is simply guessing.
You'll learn loads from your first test rides so definitely go try...
Reactions: KirstinS
Croxden
2,134
1,384
North Staffs
