Impossible, two bevel gear drives could never match chain and sprockets which are as close to 100% when new as matters.If you believe Dynamic's website, their drives are just as efficient as a chain and only weigh about a pound more.
Tend to agree.Impossible, two bevel gear drives could never match chain and sprockets which are as close to 100% when new as matters.
Bicycle component makers play fast and loose with efficiency figures, Rohloff's 99% and similar from NuVinci for example are ludicrous. Toothed belt makers also claim to exceed the efficiency of chain, again impossible.
Really ? I can't find that anywhere - are you looking at the uk site ?Dynamic say on their website they do not do kits
e.
The new generation of toothed belt drives have certainly improved, but they have a fundamental efficiency flaw. They are made as perfect circles, meaning that when on the toothed wheels on a bike they describe smaller circles, especially at the rear. This means the rubber on the inside of the unstretchable cords has to compress and on the outside stretch on a continuous basis. This is draining energy in a way that a chain doesn't, and cannot compare to the new chain's circa 99% efficiency.Having said that, I think a belt must come close to a chain in terms of efficiency.
From the 'common questions' section:Really ? I can't find that anywhere - are you looking at the uk site ?
Makes sense.The new generation of toothed belt drives have certainly improved, but they have a fundamental efficiency flaw. They are made as perfect circles, meaning that when on the toothed wheels on a bike they describe smaller circles, especially at the rear. This means the rubber on the inside of the unstretchable cords has to compress and on the outside stretch on a continuous basis. This is draining energy in a way that a chain doesn't, and cannot compare to the new chain's circa 99% efficiency.
The newer belts have the rubber thickness minimised to reduce the losses, but they are still present.
Then there's also the rubbing of the rubber coated teeth as they enter and leave the toothed apertures, again comparing very unfavourably with chain rollers over sprocket teeth. That's been alleviated by making the latest belt teeth very shallow, but again some disadvantage will still be present.
Very close. Toothed belts are capable of 98% efficiency (http://en.wikipedia.org/wiki/Belt_(mechanical)). Can't find good figures for a chain but by the laws of physics it must be less than 100%, so they're extremely close. Compared to other losses, I think you could consider them to be identical.Having said that, I think a belt must come close to a chain in terms of efficiency.
Alignment is extremely critical, the slightest error and the belt quickly destroys itself. At one time I used to work on equipment that relied on a number of these belts, hence my knowledge of them. One place where they work well and where alignment is ensured is the timing drive for car camshaft, though their life is 40,000 miles while an internal timing chain lasts practically for ever.The belt also seems very sensitive to tension and alignment.
Your ideal drive train appeals to me, although I would still carry a spare belt.Very close. Toothed belts are capable of 98% efficiency (http://en.wikipedia.org/wiki/Belt_(mechanical)). Can't find good figures for a chain but by the laws of physics it must be less than 100%, so they're extremely close. Compared to other losses, I think you could consider them to be identical.
However...this is when considering a brand new, perfectly clean and properly lubricated chain. Whilst a toothed belt is practically maintenance-free, if the chain isn't well maintained (and most aren't) then efficiency will fall off over time.
So, a toothed belt might well be more efficient in practice, most of the time, depending on your usage levels and maintenance intervals. For applications like commuter bikes (my main area of interest) I'd like to see some toothed belt drives coupled with hub gears and have the whole lot fully-enclosed from the elements. Such a system could be close to zero maintenance, which is ideal from my point of view.
Going back to the thread topic though, I'd have to give shaft drive a thumbs down. I just don't see the advantage for any type of cyclist.
Ahh that's the US website - not on the uk's FAQ sectionFrom the 'common questions' section:
Can existing bikes be retrofitted with a shaft drive?
No. The shaft drive requires a specially designed frame. All of our bicycle frames were designed specifically for use with the shaft drive, ensuring the highest levels of performance and reliability.
Sorry, but I can't agree with this for our application. The Wikipedia article says that those with chevron teeth are more efficient than straight teeth and can have efficiency up to 98%.Very close. Toothed belts are capable of 98% efficiency (http://en.wikipedia.org/wiki/Belt_(mechanical)).
