Longer Seatpost
eFred
27
Am going to fit a kit, probably from yose power, to my folding bike. I could do with a longer seatpost. The one I have is 50cm and could do with a 60cm post. It’s diameter is 30.4mm. Can’t find anything. Any ideas would be much appreciated
eFred
27
The shim is just for fitting seat posts of different diameters. I still need to find a longer seatpost.
richtea99
440
283
or
and add a 27.2 -> 30.4 shim.
I'd want to be very sure of the quality before placing my posterior on such a long post though.
eFred
27
Fair point about the quality, was also thinking that I’m not convinced about using shims either. With the length of the seatpost there’s going to be a fair bit of pressure on the frame and clamp.
3,195
If you do decide to shim - this is "Up to 90 mm (3.5”) longer than our stock post", however long that is:
