LifePo4 ebike full build
James28
24
12
Building an E-bike is something I've wanted to do for a very long time and last year I finally got round to it, hopefully there is some value in here to anybody looking to do the same thing.
In this write up I will cover pretty much my whole build and share my experience and hopefully inspires some people enough to build something themselves.
The main reason I wanted to build an E-bike rather than buy one is because you cant buy an E-bike with Lifepo4 Cells. Something that really doesn't seem to be common practice amongst builders. Most seem to believe they are old technology and have no place on an E-bike, some even go as far as saying there is no benefit whatsoever but I disagree.
I'm hoping this build will show people it is a more viable chemistry for an E-bike than people give it credit for and help anybody build a similar system that values the same advantages lifepo4 possesses over Li-ion cells that I do.
Why was I so set on using Lifepo4?
The biggest reason for using Lifepo4 was the safety factor, there is enough proof out there that LI-ion cells can spontaneously combust and how hard it is to get lifepo4 to do anything interesting in this regard. Yes I know its rare and the risk can be mitigated through safe charging/discharging practices, storage, BMS, ECT, but it can never be fully eliminated and for me if this ever occurred living in a 2nd floor flat my options are pretty limited in the event of a fire.
Lifepo4 is good for 2000 – 3000 cycles vs the 500 of li-ion. To me this is a no brainer on a commuter as it just enhances reliability and cost saving when batteries need replacing.
Li-ion doesn't do particularly well in temperatures below 0C so with a bike parked outside on days where the temperature barely reaches -5C in the winter (such as the winter just past) you'll end up pushing that battery pretty hard. Lifepo4 is good for -10C and will suffer far less in winter conditions (I'll share my observations on my on battery later).
I know there are obvious advantages on using Li-ion over Lifepo4 but none of these I view as critical unless building something insane such as 1kw+ builds.
  • Higher energy and power density
  • high quality cells are far easier to source
  • far more people have tried and tested builds with Li-ion
  • Lifepo4 is heavier (I really don't see the issue with the small weight penalty when your being propelled by an electric motor) space is much more important IMO.
  • You get better range for the same size with Li-ion but unless you need 30+ miles no pedalling at 25+mph then its not such a huge issue.
Hopefully I have made my case clear for the lifepo4 chemistry.
The cells
Sourcing Li-ion cells and designing them into a usable E-bike battery is quite frankly easy but with lifepo4 its not so much due to their very limited availability in smaller sizes. I spent a very long time searching and weighing up my options considering factors such as
  • cell size and weight (this varies wildly with different cells)
  • energy density
  • cost
  • ease of assembly
I eventually settled on a 15AH 33140 cell made by Guoxuan, I found out that a huge number of these cells were ordered by a large American car manufacture (the brand wasn't stated) so I figured if they were good enough for them they were good enough for me.
The cells weigh 276g and have an internal resistance of 15 milliohms when I tested them. I load tested each cell with a 15 amp draw and they returned 14.5Ah or 46.4wh. Lifepo4 voltage falls off a cliff when it becomes empty so I stopped my test just as this started to happen (2.8v when under load in my case), I did test beyond this and got 15.5Ah but I didn't feel this would be useful in the real world.
This leaves me with an energy density of 168wh/KG and 387wh/L.
For the test I used a cheap battery tester from Aliexpress, I supplemented it with a fluke multimeter and an ammeter for more accurate results.
Something to bear in mind Lifepo4 cells are only able to comfortably produce about 1.5C of current draw. So in the case for these cells this is a little over 20amps (plenty for a modest ebike build). I Found that most sellers vastly overstate the performance of these cells stating ludicrous discharge rates of 5C and internal resistance of 3 milliohms, these cells are capable of nothing like that but they are plenty good enough for my application.
There are plenty of sellers of these cells on Aliexpress and can be found easily by searching 33140 lifepo4 cells.
The Battery Build
Designing the battery itself was the hard part. The cells are large enough to not need any parallel connections so I built a 12S 1P pack For 36v. For those that don't know Lifepo4 has a nominal voltage of 3.2v a cell so more are needed to reach 36v.
Because the cells are so large (33mm x 140mm cylinders), I decided to make a dummy pack out of some PVC pipe the same size as the cells to make sure my design would fit my frame before purchasing any cells.
I know usually people hot glue or similar 18650s together and join them by spot welding nickel strips. This is fine when the current load is split between parallel connections and multiple strips can be used to make the series connections but not when each cell is carrying the full load.
Nickel strips were out because they cant carry 20 amps without being massive, I couldn't economically spot weld it to the copper contacts of the cells anyway. Copper contacts were the only option but this is even harder to spot weld so that was also out of the question. I tried soldering the cells together with copper strips and a huge soldering iron but I found this just heated up the cells no matter how fast I was and I ended up destroying one.
So in the end my solution was to use copper strips between the cells to make the connections and compressing the whole pack with threaded rod. I used indium shim between the cell contact and the copper contact. Indium very effectively cold welds to copper and will creep into all the imperfections in the copper giving a much better contact. I annealed the copper plates to soften them up to aid conformity when compressing. I guess some sort of conductive compound would work too. ( the cross sectional contact area is about 70mm2 which is more than enough)
51470
(I used 3 banks of 2x2, 4 cells in each bank this is a design I'm working on for a 16s Pack)
I managed to find some brackets designed to hold these cells together and I used some G10 plate in-between the banks of cells to hold the copper contact plates.
51471
I hope this is clear as to how I mounted the copper contact plate through a slot cut into the g10. The black strip in-between the g10 and the copper plate is just some rubber for some expansion room.
So there we have it, a 36v 550WH pack capable of 20 amps constant discharge which gives me about 700watts available.
The whole pack including all the fixtures and contacts weighed in at 3.5KG giving a energy density at the pack level of 157wh/kg and measured 70x70x440mm giving 255wh/L.
I used a simple Daly BMS which seems to be working, the pack has stayed in balance over the last 500 miles.
I brought a 5 amp lifepo4 charger to charge it which would take 3 hours from completely flat to full, not that I ever drain it that far.
51472
I have since tidied up all of my wiring, just one of those smalls things that I didn't plan too well initially, this was my first battery build after all)
Motor and controller
As this was my first E-bike build I wanted to use something tried and tested. So I went for a 9 mosfet KT sinewave controller rated for 22 amps in conjunction with a kt lcd 3 display.
My motor is a rear bafang G020 250w code 10 motor, this runs at 310rpm.
Enclosure and mounting
I think this was the hardest part of my build considering my requirements.
  • wanted all components housed in a single enclosure
  • clean wiring
  • completely waterproof
  • removable battery
I've seen some pretty dodgy looking DIY E-bikes out there and I didn't want to fall in to this camp. I also see a lot of bikes id be scared to take through a small puddle and some that look so illegal they are just asking for it to be confiscated.
Enclosure
I decided I wasn't going to over engineer this, I felt I should build my first revision just to see how it went. I used some PVC angle to make a frame and covered it in panels made from 3mm PVC sheet. Its really easy stuff to work with, waterproof and it glues together very well using plumbers cement (basically jellied acetone).
5147351476
I fitted some neoprene foam to the battery pack in an attempt to give it some shock protection, i'm not entirely sure it was as successful as I was hoping but I think it does something.
Mounting
Actually mounting this 5kg box to a bike is pretty tricky, its far too much to hang off of bottle cage mounts so I fitted 10 small 15x15mm spacers made from PVC with an m5 heli coil through the middle to the bottom of the box which sit in holes I drilled into some aluminium plates which are held onto the frame with exhaust clamps (I used the bottle cage holes just to align the larger plate to keep it central). The pictures hopefully explain this better.
5147751479
I used some plastic tube and some waterproof aviation connectors to get the wires from inside the box to the outside while keeping it all water tight. The connectors allow me to disconnect the battery box from the frame. I made the wiring loom in a similar way, I basically have 1 tube running down the frame to the motor and 1 up to the bars. I tested the waterproofing by dumping everything in the bath.
Switch
I wanted to have a main switch to prevent the capacitors in the controller from being charged constantly, so I found a 24v switch rated for 25A DC (I know its not ideal but its very hard to find something of a reasonable size, its not switching full current so I figured it would suffice). Its a double throw switch. I fitted a 0.15ohm 5w resistor to one side and the main current lead to the other. The switch with resistor will charge the capacitors in the controller slowly before I switch to main battery power. This will prevent a large spike of current through the switch which could weld the switch contacts together.
51481
Finally
So none of this actually matters until you put it all together and take it out on the road. In total I added about 8kg to the bike considering what I get out of it I was very happy.
Weight was a considerable factor in this build because I have to lug this thing down 3 flights of stairs to get it outside which is why I fitted all this to a road bike frame. The whole bike weighs around 18kg.
My commute is 8 miles a day and I use it for 3 days until charging. I give the bike basically no help at all and it can carry me along at 23mph (obviously I run at 15mph for legal reasons). When I did my range test I got 30 miles like this.
I have no throttle and only use the pedal sensor to engage the motor so I just spin the cranks and it moves.
I have the current set on the controller to about 11 amps giving me about 420watts and get a voltage drop on the battery of about 1.2 volts this is more in the winter after the battery has been out in the freezing cold all day where I see a drop of 1.7 volts.
I'm not going to stop with it here, I plan on rebuilding my enclosure from carbon fibre to make it smaller and lighter and building a 16s battery to get 48v with a better smart BMS and a voltage converter so I can run lights off the main battery.
Well done if you made it this far, I hope my experiences with this have been interesting and given some ideas to people. I have tried to design this so its can be built with minimal tooling and a bit of skill, I built this in my bedroom without anything more than some very basic tools.
I'm more than happy for any questions, criticisms or improvements. More discussion can only be a good thing. Thank you for reading.
5148251483
matthewslack
2,594
1,671
Is the indium shim readily available, and is it expensive? It sounds like a step forward for compression contact battery packs.
Good job.
3,411
Looks great!
Could that double switch be snagged by clothing or something?
James28
24
12
Good job.
Its about £15 for a sheet from aliexpress for 100mmx100mmx0.1mm. I have access to an xray machine at work so i tested it for purity, the xray showed 99% + purity
Reactions: matthewslack
Dave Elderfield, MD of very successful motor sport company Rally Design, had a brave try when he set up pedelec company Kudos Cycles in the 2000s, equipping a selection of his pedelec range with LiFePO4 batteries, giving consumers the choice in affordable pedelecs. But the consumer market didn't support his efforts so Kudos Cycles eventually died out.
Well done on your build, neat job.
WheezyRider
1,690
938
Nice build. Interesting the use of the Indium foil. Have you thought about using Indium solder? It has a melting point around 118 C, so it might be possible to use that without overheating the cells.
James28
24
12
I did consider it but the mechanical stregnth is no-where near as good as leaded or unleaded solder. My design at the time needed a decent mechanical bond between the cells. I know you shouldn't rely on solder for that but its plenty capable on joints of this size.
I did try to assemble the pack in such a way that i could remove a cell if needed but this didnt work out too well in reality and it was a real pain to get the bad cell out.
After destroying a cell and wrestling the thing out of a fully built pack i decided to redesign it so it was a bit more serviceable. Now its just a few nuts and the pack is disassembled in minutes without pulling it around too much which i felt just stressed all the other terminals on the batteries.
I use indium bismuth solder a fair bit at work and it melts at an even lower tempreature (about 70C). Im pretty confident using this wouldn't heat up the cells very much if at all past what the recomended limit is for the cell.
My choice to use the foil was purely based on ease of assembly and dissasembly. Copper is only 5 times more conductive than indium and my joints have more than 5 times the surface area recomended for the current im drawing.
I retested the resistance of the battery after assembly and saw no difference between a built pack and the individual cells.
Reactions: guerney
nigelbb
511
422
I didn't realise the significance of the LiFePO4 battery but they still had stock when I inquired a couple of years ago. The Kudos Safari looks a bargain at £695.
Even better was this offer in August 2017 as they were trying to clear stock:
"Kudos Safari super deal, buy two bikes for £995.00 including delivery to UK mainland addresses."
Stunning value for such extremely well equipped 36 volt pedelecs.
I'm not sure they are still operating though, Twitter and Facebook activity seems to have largely dried up since 2017 and their site's dealer locator link isn't operational.
nigelbb
511
422
A couple of years ago I exchanged email with them at sales@rallydesign.co.uk I got the message "We have black or silver only and size 43cm only in stock now."
