Levo chain ring
Taffyteg
7
50
Warwick
Hi. I have a 2016 / 17 Levo and I would like to drop the chain ring from 32T to 30T. Basically I want to run the motor as low as I can and I find the gearing is too high on single track climbs.
I have looked at 30T hope chain ring but the 2ish mm offset looks to me as though it might rub the motor cover and it would also misalign the chain to the rear - would the mis-alignment be a problem?
cookiee
16
12
Australia Albany WA
I would be interested is you find something suitable as well, I think specialized only do 32/34t chain rings and are hardened steel. Looking at mine it doesn't seem like there's much room to go smaller in diameter.
You could go SunRace MX8 11-speed Cassette 11-46 .
Trevormonty
1,135
564
17
NZ
If it is 10spd sunrace do 11-42t cassette. Do some research first as derailleur may not be able to handle larger sprockets.
Taffyteg
7
50
Warwick
I did look at going for a larger cassette but that would mean changing the rear mech also :(
cookiee
16
12
Australia Albany WA
Related Articles
