Middlesburn Square taper arms
I emailed them about this as the picture looks like a spider is attached to them.
Reply
Thanks for contacting us but our cranks do not come with a spider or ring attached. In fact you buy the cranks with nothing on them and then add either a spider or direct mount chainring. So you can use our cranks, it’s just that the right hand crank would have splines for fitting our parts on which wouldn’t be used.
We are in fact about to make some E bike cranks but those that fit on the ISIS spline type of BB.
To produce the cranks you are looking for would be very easy and very straight forward as it’s just a copy of the left hand crank but as I said you can use our cranks on a square taper BB even as they stand now. Hope that helps.
