Does anyone know what the chainline ends up at if using a Lekkie 42t Bling Ring on a 68mm bottom bracket, on the Bafang BBS02?
All I can find is stuff like "9mm offset" but that's meaningless to me, I just want to know what the chainline is!
The Lekkie website says:
"Offset: 9mm – see User Manual for more information (stock bafang 5.4mm)"
If the stock chainring creates a 50mm chainline (according to the BBS02 schematic) and the Lekkie chainring has 3.6mm more offset than that, the Lekkie chainline ends up at 46.5mm right?
I think on my setup that would be literally perfect. I can always put 1mm washers on the bolts between the motor body and chainring to end up with it at 47.5mm (what it probably should be on my MTB).
Cheers.
Cheers.
