LED Display error
Rebecca Gillett
Dec 28, 2022
Hi, I've had my Pendleton E-bike for 4 years now with no issues until last week. Although the battery is fully charged the Mode LEDs Low and High have started flashing together and all power is lost. Do I need a new battery?
8,841
The low and high both flashing is related to a brake sensor issue, disconnect both brakes to see if the bike works again. If so reconnect each brake seperatley to find which one is causing the fault.
Light CombinationDefinition
indicator light flash(LOW level)abnormal current level
indicator light flash(MED level)abnormal throttle level
indicator light flash(LOW+MED level)motor phase level
indicator light flash(HIGH level)Motor hall signal level
indicator light flash(LOW+HIGH levels)brake level
indicator light flash(LOW+MED+HIGH levels)Abnormal communicationlevel
Reactions: Rebecca Gillett
