I've recently installed a Yose power kit and I'm trying to set up the LCD.
I managed to get into the advanced settings, but I'm not sure what some of the values should be set to.
With the Speed sensor selection (SPS) This has the option of 1 or 6. Does it matter which?
The sensitivity of the PAS setting can be from 2 to 63. Is a higher number better or worse? Is this the sensitivity of the signal pick up, or how strongly the controller ramps up the power?
What does the throttle level option mean (Hfn)?
With the Slow Start Up (SSP), is 0 rapid start or slow start?
Thanks for any info you might have
