Hello, I have come by an older lafree twist (2002) which has stopped working. the battery takes a charge and shows a full set of lights on its side. The switch seemed Ok, as when you switched on it lit up for 2 seconds and then went out as it says it should in the manual. I have taken the switch apart as instructed on fleccs lafree technical page. Inside there was a small amount of moisture and signs of corrosion to the board. Can the corrosion be stopped/fixed or should I move straight towards sourcing a replacement switch ? I have a photo of the switch corrosion if that would help with the diagnosis!
Any help much appreciated, Mitty
