ku65 controller over current
patpatbut
860
79
I received the KU65 controller from BMS battery and the label on the controller has the following details
KU65 High Speed Controller
For 36v battery
Over current : 30A
LVC: 27.5
For hall sensor motor
For sensorless motor
What does it mean by over current? I thought the discharge current for this controller is around 15A.
Pat
NRG
2,592
10
Not sure but the phase current can be 2x the battery current so perhaps this is what they mean, a limit on the phase current the motor 'sees'. The LVC seems a little low normally its around 31.5v +/- 0.5v
For 36v battery
Over current : 30A
LVC: 27.5
Pat
The temperature control circuit sometimes shuts them down at 15 amps, so I don' believe that they could take 30 amps. That must be a mistake on the label.
