So I am putting on a new front cog, chain and cassette and I notice that I have been riding with a loose 10nm tourque nut in the rear suspension.
It is from the short rocker, about 200mm long, that pivots on the big tube from the seat to the bottom bracket.
I tightened it up but I notice now if I lift the back of the bike off the ground for a second or two and pop it back on the ground there is a "clicky" noise. A closer inspection shows there is some play in the same bush that I tightened.
Question (s)
Was hoping to get back on the road this weekend :-(
Question (s)
- Is a bit of play normal?
- Would I have damaged the housing or the bush or both?
- How easy is to get a new bush?
- If the housing is damaged what can I do?
