I have a Dillenger Opia 2 folding bike. It came with the controller and motor per photo and a 5 wire LED display model key-disp KD-26. In the hope that an LCD display might be compatible with the controller I have purchased a KT-LCD5 display. I've connected the display and tried a few things in situ (i.e. not taken the bike on the road). Lo and behold I have some problems.
The positives are:
The positives are:
- LCD switches On/Off OK with no errors.
- Throttle works
- Motor kicks-in when turning the pedals
- LCD backlight works but bike light does not come on
- Battery voltage is correctly displayed numerically
- Battery voltage is not displayed graphically UNLESS P5 in the paramter setting is set to 00
- Display backlight is illuminated when UP is kept pressed but front bike light does not come on and no voltage detetcted on the connecting wire using a mutimeter
- When DOWN is pressed Walk Mode is not triggered
- Speed etc is not displayed at all
- Pressing UP/DOWN changes the PAS from 1 to 5 although I can not detect the actual effect as I have not taken the bike on the road.
- give up and buy a compatible KT controller. If so what and where from?
- play with P & C parameters. If so then what should they be?
- assume the display is faulty and return for refund?
- something else?
