May 5, 20214 yr This is a kit I built up for my daughter's trike. For some reason the display just shows 0.0 for speed and distance. Everything else works fine. Is this a setting or maybe something is broken? It does show avg. speed, so something most be registering. Also, is the new KT LCD8H a direct replacement? Thanks!
May 5, 20214 yr Is this a new fitted kit or one that has stopped showing speed once fitted ? LCD8 isn't a replacement, just another compatible display.
May 5, 20214 yr What sort of speed sensor are you using. Is it a wheel magnet type or one in the motor?
