June 29, 20178 yr Hi all, I had "00 info" come up briefly on my KT LCD3 today but can't find any info on it, the only codes I can find are 01-06. Does anyone know what 00 means? Info: I've had what feels like a slightly intermittent throttle for a few days but have been unsure if that's just me not holding it steady on the really rough cycle path. Controller is a KT60SVPRK-SLS02G. TIA, Jon
June 29, 20178 yr Although not listed I have seen '00' on another error code list. 00 Control unit communication error. So wiring needs checking esp connectors and pin connection for tightness.
June 30, 20178 yr Author Hi Neal, Thanks for the reply. I found the same information but wasn't sure if it read over to my controller/LCD. Anyway, I received a replacement throttle from the vendor and whilst changing it, I re-seated all connectors and taped them together. The throttle seems to have cured the intermittnet fault and I saw no codes this morning on the way to work, so hopefully it's sorted.
