Interesting that this post came up now as I am about to order a kit today!
I've been doing research over the last few weeks and plan to put something together as none of the off-the-shelf bike options quite fit what I'm looking for. That is a fast, simple, light, visually uncluttered bike for commuting over a relatively flat but long route, where I am able and willing to give significant pedal input. Essentially I am looking for something similar to the T-bike created by Flecc, but equipped for commuting with mudguards and rack.
I've considered Heinzmann, Crystalite and Tongxin (aka Nano) kits. I ruled out Bionx mainly on price but also because I didn’t like the ‘fuel tank’ style battery.
I’m going to fit the kit to a 700c wheel on my existing Marin hybrid to give a bike capable of cruising at or slightly above 20mph, operating at 36v. Initially this will be powered by an SLA battery I have lying around in the garage but, if the concept works, I intend to replace it with a new NiMH. The SLA can be a handy back-up for very long trips, weekends away or emergencies.
From my research, I've come up with the following pros and cons:
Heinzmann
For – proven quality and reliability, powerful, good choice of UK suppliers
Against – heavy, noisier, brushed motor gives peakier torque curve hence may be less efficient so lower range, most expensive, daft-looking batteries (but could get alternative)
Crystalite (406 model)
For – powerful, good reports of quality, relatively inexpensive, good choice of motor options
Against – some rolling resistance (they do have a brushed model apparently has lower resistance but is noisier), range may not be great
Tongxin (36v 260 rpm)
For – very small, quiet and unobtrusive, low rolling resistance, good range, good choice of motor options, cheapest
Against – some reliability issues reported, especially in applications where high torque has been required (or in daft configurations, eg Schwinn). Moderate peak power output (360W, which is higher than my wife's powacycle but much less than the other kits) so would need to be geared for either speed or hill-climbing as motor unlikely to be up to both.
Obviously power and range are the opposite sides of the same coin – a more powerful motor will have a lower range for a given battery. I think the choice between these three comes down to the following:
- For someone who wants the most proven option and prefers the simplicity and back-up of a UK supplier, but doesn’t mind paying a bit more, Heinzmann seems to be the safe bet.
- However if you don’t mind ordering from overseas (ebikes.ca mentioned by Jeremy seems a good option) and are willing to sacrifice the German quality engineering, the (Chinese-made) Crystalite kits seem to offer pretty much everything that Heinzmann does, at a cheaper price and lighter weight.
- Tongxin is a slightlier riskier option given quality/reliability concerns but offers a lower power/longer range alternative for those who don’t mind doing more pedaling, and who value its low impact on the bike (small size, quiet, low rolling resistance).
I won’t say what I’m ordering yet as it may not work and I might have to change things, but I’ll post again when I have made some progress – which may take me a few weeks as things are busy at work right now.
Regards,
Frank
PS I wrote this this morning but not been able to get on the site for a few hours so couldn't post.
Jeremy - particularly interesting to read your experience with a high powered Crystalite and also your comments on Crystalite vs Tongxin, which chimes with what I have picked up elsewhere.
