King meter j-lcd repair
Anthonyexmouth
253
27
53
Exmouth
Just a simple bit of advice.
Just had an issue with my head unit.
Started showing "Lu" when starting up. This is a low internal battery warning. Changed battery but still getting low voltage error.
Found out it's easy to insert and catch little brass contact. Also noted that battery holder was a bit loose and no continuity between terminals on holder.
Anyway. If anyone else encounters this I have just replaced the horrid holder that's soldered underneath with a better one with short leads to the appropriate terminals on the main board.
It's a very easy fix.
It's not a big problem as it only holds the clock time but it's annoying so if anyone else has encountered this it can be fixed.
