Hi all. I just picked up my new Kalkhoff Impulse Ergo XXL. I had some problems with it right away: the magnet mounted on a rear wheel spoke is hitting the speed sensor placed on the frame next to the rear wheel. I took the bike right back for an adjustment. It seemed to be fixed in a short test in the parking lot. But soon after resuming my trip home I heard that "thunk thunk thunk" from the rear wheel. The problem seems to become particularly obvious at higher speed and after I've been cycling for more than a few minutes. However, once I start hearing the noises, it doesn't go away until I stop. I have checked and when I look at the clearance between the sensor and the magnet, it seems there's a sufficient gap that there should be no contact. But there is, unless something else is causing the noise.
(I didn't have time to go back for a second time today, as the mechanic had left.)
This is not the first time I've had a Kalkhoff bike. The Impulse Ergo is a replacement for an earlier 2012 Kalkhoff Agattu XXL which was declared not usable by my retailer's mechanic. The fatal issue was that the area of the frame where the rear wheel is secured had worn down, making it impossible to lock the wheel in place. This was said to be caused by having taken the rear wheel off and putting it back on too many times. One of the earliest problems I had with that bike was this same issue of the spoke magnet hitting the speed sensor.
From my experience, there are a couple of issues involved with this particular problem. There's the issue of the wheel being properly centred, then there's the question of whether the speed sensor is close enough to the spokes (or too close) - with some spacers that can be removed under the sensor. There is another problem if the magnet is too far from the sensor - the motor assistance level drops to a low level and the handlebar controls flash. I learned all this from my experience with the Agattu.
To any of you who say this is an easy fix, I should say that I've concluded that I am not able to properly install the rear wheel on Kalkhoff bikes, as I can't seem to centre the wheel, ensure sufficient chain tension, keep clear of the sensor and tighten the wheel all at the same time. (Especially as the wheel bolts tend to get stripped if over-tightened. I don't have a torque wrench, nor do I know the correct tightening specifications for the bike's bolts.)
I don't know why I keep on having this problem with Kalkhoff bikes. I also don't want to do anything that might damage the bike. Can anyone give me some tips on how this should be handled? Why would the spoke magnet only start hitting the sensor only at higher speeds and after a certain amount of time?
I look forward to any input.
Mike
Mike
