Kalkhoff Ergo impulse XXLi360
Kit Taaffe
Aug 2, 2016
Anybody with one of these bikes let me know what they say a them interested in knowing about the auto gears are they similar to an 8gear or 10 ratio wise do they stay in a gear when they are set
Thanks in general what's the difference
Kit
6,733
(admin note: moderated: opinion presented as fact, removed)
Reactions: LeighPing
D8ve
2,142
1,294
Bristol
(moderated by admin, linked to a previous post)
(moderated by admin)
6,733
Username/Model/Age/Mileage
reggie_electric - Agattu - 6 months - 800km
nemesis - Focus Jarifa - 4 months - ???
Jean-christophe Saville - S11 Alfine - 14 months - 2800 miles
Lothlean - ??? - 10 months - ??
Will Tinker - Pro Connect 9 - 5 months - 500 miles
Oriteroom - Focus Aventura Impulse S10 - 10 months - 3000 miles (3rd motor)
Roger R - ??? - 6 months - 1000 miles
nightrider - Endeavour S10 - ?? - ??
bernharvey - Agattu - ?? - 400 miles
Reseg - Focus Aventura - 10 months - ?? (3rd Motor)
lowranger - Impulse 10 - ?? - 2300 miles
Biscitt - Agattu - ?? - 350 miles
Biscitt - Tasman - ?? - 100 miles
Tomtomato - Pro Connect 10 - 7 months 900 miles (2nd fault)
nemesis
521
343
Kit
The motor that the the bike uses should be the main priority,so look for models using Bosch,Yamaha and Shimano as these are the most reliable and have high performance.
HelenJ
Administrator
Staff member
May 19, 2011
220
381
Could I ask everyone to please be mindful of expressing opinion as opinion and making sure any facts can be substantiated. Thank you.
  • Useful
RobF
4,732
2,312
At the risk of appearing old-fashioned, I will attempt to answer the OP.
The bike has the NuVinci 360 gear hub - the percentage range is indicated by the model number - 360 - so you can compare that will other hubs.
The gearing on a NuVinci is constantly variable, so it doesn't have stepped changeable gears, but it is always 'in gear'.
The auto version alters its ratios automatically in response to cadence and pedal effort.
It's unusual for a bicycle, but works well enough once you get used to it.
There's also a twist grip manual over-ride, which also works fine.
There's no clicks, you just twist the grip a bit one way or the other to raise or lower the ratio.
The downside with the NuVinci is it saps power, which is why it hasn't caught on for pushbikes.
Losing a bit of power is less of a problem for an ebike, but the same motor on an ordinary hub geared ebike will still feel a lot more lively.
6,733
and mine lol, i think 50c dont like the fact that the impulse motors are kak and not fit for purpose and they all go wrong bar nigel01 bike.
prob why the main thread was locked yet the brexit one is still open on a ebike forum.:rolleyes:
fact is they should make for an excellent small boat anchor ;)
Reactions: 1 person
