A word of caution since it appears you may have just bought the bike. Are you sure the motor unit is working before you buy an expensive battery?Hope someone can help
I am looking for a replacement battery for Kalkhoff Agattu pedelec .
previous owner stamped dates on charger, first charge 2008 so assume bike is 2008 ish
the charger number is NKJ039
output : dc 29.3v 1.8v
Class 2 battery charger
Thanks for quick response, can I ask, how do you know Kalkhoff model ? I see Kalkhoff aguttu but no numberThat will be the version with the Panasonic 26 volt motor, later they used different motors. There's various sources online for these quite expensive batteries, available in various capacities:
Here's one web site with a choice if you scroll down,
It was released at the end of 2007 only as the Kalkhoff Agattu.Thanks for quick response, can I ask, how do you know Kalkhoff model ? I see Kalkhoff aguttu but no number
Thank you greatly appreciated for your responseIt was released at the end of 2007 only as the Kalkhoff Agattu.
Later they introduced a version with a Panasonic front hub motor so to distinguish the two, the one with the centre crank motor was called Agattu C, the one with the front hub motor was called Agattu F.
However both used the same batteries, originally 8Ah or 10Ah but later larger ones.
Please see my cautionary post just above yours.
