Kalkhoff Agattu 2017 55cm Step Through
Stephen Gray
126
20
66
Winlaton Mill 6 miles from Newcastle
Bought new in April 2017 (have receipt) cost £1,450.
Original 11Ah 36 v battery replaced with 17Ah version, a £400 upgrade, see 50 cycles website to confirm this.
Owner was 87 and never took bike off road. Always kept indoors and battery topped up after every ride.
Only 360 miles on clock.
Magura hydraulic rim brakes, hub dynamo bright lighting, pannier rack, walk assist mode.
Selling due to upgrade to Gazelle with Nuvinci hub.
Any interest at £1,000 ono ?
In Winlaton Mill 6 miles from Newcastle. Nearest rail station Metrocentre 3 miles. Lots of hills to try it out round here.
8,529
Most are wise and weary if Impulse 11 drivem might be better to off load on Ebay.
Reactions: oriteroom
Stephen Gray
126
20
66
Thanks Neath. Not sure if you mean Impulse 2.0 ? which it is.
I know Impulse has negative posts here. All I can say is, touch wood, we have had no problems at all with two of them. My friend has also owned a few from new, no problems. Are we just lucky or do we never hear about the examples which do not fail ?
8,529
Same with most things you usually only here of the failures or bad service.
A lot of the Impulse II failures is most likely from those that use them more or push the drive harder.
