Can any one tell me what the diameter of the axle is for this thing ?
I dont see any reference unless i missed it .
thanks
tepol
Hi Frank,the axle diameter on thread is 9,5mm outside, it is a BC-3/8"
regards
frank
PS: i want send you a technical drawing of the SWXK(jewel) but the attachment-function dont work since some weeks. anybody have an idea what i´m doing wrong? maybe i setup something wrong? when i go to the forum it has worked, maybe this function dont like me ;-)
belief me, it is 3/8" this is metric outside diameter 9,5mmMy reading of UNIQUE——swxh series -Suzhou Bafang Electric Motor Science-Technology Co.,Ltd and JEWEL——swxk series -Suzhou Bafang Electric Motor Science-Technology Co.,Ltd is that they're standard sizes. 8mm and 10mm flats for the drop out width, 10mm and 12mm nuts, 100mm and 136mm drop out spacing, for the front SWXK and rear SWXH respectively.
Sorry, I'm getting it wrong.belief me, it is 3/8" this is metric outside diameter 9,5mm
if you look on the technical drawing you can read this "2-BC 3/8" for the axle diameter
As a bafang dealer i have the Motor here to check and also i have the technical documentation from Bafang SWXK here ;-)
Maybe it results from dealing with the USA and Europe and trying to please both Frank? As an engineer in Britain I've freely worked with both for many years, including mixing them. I do it all the time and find it an advantage, both Imperial and metric have their advantages in different applications and areas of life.Dont ask me why the chinese mixed mm and inch , i also relly hate and i belief there is no reason, the one who take responsibility for the thread maybe was an old guy and had learned to use inch and the one who design the motor was young has learned to use mm i have no idea
regards
frank
I feel a bit stupid asking this but am I right in assuming flats is the term to describe axels that have been squared off i.e. so as you say they dont turn in the fork ?belief me, it is 3/8" this is metric outside diameter 9,5mm
maybe i make some photo on my website about this, as long i´m to stupid for the attachment it´s my only chance , wait i do it with some photo from axle and thread and torque washer
regards
frank
Yes. I'll leave Frank (Mechaniker) to answer your other queries.am I right in assuming flats is the term to describe axels that have been squared off i.e. so as you say they dont turn in the fork ?
thanks FleccYes. I'll leave Frank (Mechaniker) to answer your other queries.
Hi tetpol,Is that 28 mm bearing with ID of 12 mm that one you use in Jewel ? ( the far left one )
The thread for my bolt / axle is 9.5 , but the bearing I have is only 22 mm width with an ID thats maybe fraction bigger than 9.5 i.e. by 1mm i.e. 10.5 - 11 mm
Greetings Frank,Hi tetpol,
on the left side, diskbrake side is a a 28mm/12mm bearing if i remember right. but your idea dont work.
I had a look on your picture´s and i belief to know what you want do but i see no chance to do it this way.
it is more easy to design/modify your knee-cruiser new.
If i would like to do what you want do i would build the hub in the middle and use the right and the left wheel to keep the balance. I would build the forkarm for the motor a bit flexible because the angel you use the knee-wheeler is not always the same. So i would use a spring-mechanism
regards
frank
