iZip Owner Reviews
RichardB
46
Submitted by: Simon Jones
Model: Izip Mountain Gents Trailz Enlightened Electric bi
Retailer: Powered and Electric Bikes stockist in Nottingham, UK
Purchase Price: £1,034.99
TimeOwned: 18 months
Terrain: Moderate Hills
Strengths: excellent
Weaknesses: none
Summary: The service from poweredbikes is fabulous..we` ve been delighted with the izip bike, it`s revolutionised family bike rides.... can`t recommend highly enough!!!
Overall Rating: 9
MazB
58
Izip Mezza Enlightened
Reviewer: MazB
Purchased From: Atmosphere Bristol
Purchase Price: £950+ with discount
Time Owned: Approx 3wks
Local Terrain: Moderate/Steep Hills
Strengths: Power Size and Weight
Weaknesses: None at the moment
Summary: I was very dubious about paying out so much money for the IZIP as I really wanted the Wispa Folder but opted for the IZIP as it had the throttle, something I felt I still needed as I cant always just use pedal power due to health issues (yawn!).
I also have the UM55 which is a great bike but I needed a folder as I have changed jobs and needed to take the bike into the office.
So far I have been well impressed with the IZIP. It folds in seconds and it feels so light compared to the UM55. Once folded it fits nicely under my desk.
I've never had a bike with disc brake (front only) before and oh my god is that scary the first time you do an emergancy stop! Nearly went flying :eek: but have now learnt how to use it properly.
The size and weight of the bike is perfect, although the weight felt scary in the wind as I suppose I was used to the heavier UM, but again you get used to it. The size is great for short or tall people and at 5ft its always a problem for me to get a bike thats comfortable as well as feeling safe and in control and I feel totally at home on this.
The power is amazing, as I would expect as it has a 36volt motor, for my usage goes up hills with no effort much more effective in pedelec mode as opposed to the throttle. Switching between the pedelec and throttle is a simple switch on the handle bar. It has 7 gears which is sufficent for my needs and I havn't struggled as of yet in tackling any terrain.
When I get a straight run and a good road surface I can get up to very good speeds :D .
Overall I'm impressed but its early days but it feels like a good sturdy bike and I'm very happy :D
Overall Rating (8 of 10) : as I've only had it 3wks I'll wait to give it a higher mark to make sure it continues to be sturdy and all the bits and bobs last.
HittheroadJ
152
16
Northern Ireland, BT1
Meerkat eMotion / Currie Izip AL
Reviewer: HittheroadJ
Purchased From: Amazon UK (Moore & Large)
Purchase Price: 374.66 (Free Delivery)
Time Owned: 2 Months
Local Terrain: Moderate Hills
Strengths:
- My first electric bike brings a smile to my face when I ride it and I cycle a lot more than I used to.
- Value.
- Reasonable Hill climber.
- Front Disc brake & suspension.
- Pedal Assist & Throttle mode + easy switching between them.
- I have used the bike to tow a children's bike (trailgator towbar) and with heavy bags of shopping. The heavy bike feels secure and solid with loads. Limit is 109 Kg's though.
- Limited purchase price means it can be added to home insurance (up to 600 per bike, in our case) the limited purchase price also means I can go into town and park it without being too concerned about it getting stolen.
Weaknesses:
- Heavy.
- Old technology.
- No battery upgrade to LiFePo4, or any of the other modern batteries standard available. SLA will go down in power during winter.
- Not fast.
- Limited Range on standard SLA Battery.
- Noisy.
- Cannot reach On/Off switch while riding (can set to throttle mode and not use throttle).
- Need to lock battery in rack, otherwise the battery can disconnect when going over bumps.
- The low steering means you have to lean on the steering, this can cause sore wrists.
- The standard pedal assist speed is just below my cadence and I compensate with the throttle, this would be sore over extended periods of time.
Summary:
This is a review of the Meerkat eMotion as it can be bought at Argos, Tesco-Direct, or Amazon.
The bike is essentially a Currie Izip with RMB (rack mounted battery). Curry Izips are being sold at several ebike-shops and websites in the UK. In the USA they have been sold cheaply at Wallmart with a 450 Watt motor. There are many youtube videos and discussions on modifications etc..
At the price the quality of the components cannot be top-notch. On the other hand, there are people who have ridden the bike for a couple of years and hundreds or even thousands of miles.
I had my first puncture after a month of use (probably lucky) and replaced the rear tyre with a Schwalbe Big Apple 26 x 2.0. This seems to have improved the riding comfort a lot and reduced rolling resistance.
General Points:
MTB-Style look with RMB. The rack can hold two batteries. The batteries are £130 each. You can save some money by replacing the SLA-batteries inside the case, with some DIY. On the pedelecs forum is an example of someone who did that for about £60.
The bike was delivered within days, the first one was sent back because of damage in transit. I hesitated about buying a second one. Did so after about a month. The second one had a brake-pad missing, but this was shipped out by Moore and Large (a bit slow, but OK).
The bike comes with a bell and can be assembled in a reasonable time.
Riding Experience:
The battery hangs on the side, but this does not affect the riding behaviour.
The bike feels heavy. You can ride the bike fine without the motor on the flat and descents, but climbing will be very heavy without the engine engaged. I would not take it for long rides.
The seven gears work fine.
I have had slightly sore wrists, from leaning on the steering, on long rides. I have also found that the constant use of the throttle can bring some discomfort to the right wrist. It would be nice if you could set the pedal assist to a slightly higher level, I have found myself giving some extra throttle for longer periods of time (in Pedal Assist mode you can increase the power with the throttle.).
With engine the bike is a joy to ride.
I have used it for commuting 4 mile in and 4 out, with charging in between if possible. This worked very well.
With heavy loads or kids in tow the help of the motor really makes a lot of difference, particularly starting away from traffic lights going uphill has become a lot safer.
In most cases many cyclists will overtake you, but going uphill or into a strong headwind the extra power makes it hard for others to keep up.
Most ascents of hills and steep streets can be taken in 3d or 4th gears. I rarely get out of 7th gear. This also means that the fluctuations in travel time are greatly reduced.
I have done some "fun" rides of 14 miles and one of 17 miles. In those cases the power went down significantly towards the end. The engine still helped, but less help was given. The motor did not cut out completely, but I did get sweaty.
I have ridden n drizzle several times and in heavy rain twice. This did not cause any problems. I avoided deep puddles, though.
I will look into fitting a LiFePo4 battery. I will also look into fitting a "traditional stye" handlebar for a more upright riding position.
If the bike wears out I would like to try to replace the engine and rear wheel with a kit (rear wheel kit from eZee? or one of the others.)
In winter the battery could be taken indoors for charging and keeping warm. I think a commute of 6 or 7 miles (up to 14 miles a day) could be realistic, if charged in between rides.
In summer the rides can be longer.
Overall Rating (out of 10) :
HittheroadJ
152
16
Review of Meerkat eMotion (Rebranded Currie Izip Trails AL)
Reviewer: HittheroadJ, June 2010
Strengths:
- Value.
- Reasonable hill climber .
- I have used the bike to tow a children's bike (trailgator towbar) and to carry heavy bags of shopping. The heavy bike feels secure and solid with loads. Limit is 109 Kg's though.
- Throttle mode available.
Weaknesses:
- Heavy.
- Old technology.
- No battery upgrade to LiFePo4, or any of the other modern batteries standard available. SLA capacity will go down in winter.
- Not fast.
- Limited range on standard SLA Battery.
- Noisy (personally, I do not mind).
- The standard pedal assist speed is just below my cadence and I compensate with the throttle, this continuous use of throttle would be sore over extended periods of time.
Summary:
I had my first puncture after a month of use (probably lucky) and replaced the rear tyre with a Schwalbe Big Apple 26 x 2.0. This seems to have improved the riding comfort a lot and reduced noise and rolling resistance.
General Points:
Riding Experience:
I have not tried to use the bike as a moped. It could/should work for a couple of miles on the flat, but I like cycling and use throttle to be quick off the mark from standstill.
I have ridden in drizzle several times and in heavy rain twice. This did not cause any problems. I avoided deep puddles, though.
If the bike wears out I would like to try to replace the engine and rear wheel with a kit (rear wheel kit from eZee? or one of the others.).
In winter the battery could be taken indoors for charging and keeping warm. I think a commute of 6 or 7 miles (up to 14 miles a day) could be realistic, if charged in between rides. The occasional long ride is fun, but I'll see over time how comfortable it is.
HittheroadJ
152
16
I bought two meerkats that I've now owned for 12.5 and 13.5 months.
The meerkats are no longer sold, but there are still occasionally izip RMB (rack mounted battery) popping up on ebay and other places.
What have been the experiences after a year?
I bought 2 (one for £374 and one for £359).
I fitted both with Schwalbe Big apples (£16.99 each at chainreacrtioncycles). In both cases the rear tyre got it's first puncture after 5 weeks. Changing the rear tyre is not easy but doable. (I put some pictures and guidance up in one of my posts).
The battery of the second bike was markedly inferior to the first.
I had a controller brake down on the second bike after a couple of months. Moore and Large sent a replacement without problems and it worked without problems.
I damaged the blocks on which the batteries rest on one bike on both sides after it bounced of a high kerb. Replacement blocks would have been £19.99 each (w/o shipping). The weight of the batteries on these bikes makes them sensitive to this kind of damage.
In june I could get about 15 miles out of the first and about 10 out of the second. In spring I started mounting both batteries on one bike. I then bought a "kit" on ebay for £145. The kit contained the blocks, the battery and a spare motor+cables etc..
I have not had downtime on both bikes at the same time. I think that is a major advantage of 2 cheapies over one, more expensive, bike. Another advantage is that I can go to the pub on one. I'd be upset if one bike got stolen, but it would not be the end of the world. Both bikes fitted within the home insurance.
A snowy winter with lots of salt/sand on the roads meant one bike's drivetrain and wheel have started rusting more than the other.
Longets trip has been aout 28 miles. Most usage has been in and around town. 4 miles in 4 miles out trips. I have often charged a battery while in town (in a place of work, in a course) nobody objects to plugging in your battery.
I have really enjoyed cycling. It has turned fro a chore into a delight. Going shopping, school run with a kid's bike in tow, visiting friends, all great fun.
I do want to go for LiFePo4's next. The limited range is just a drag. £268 for a 15Ah should do the trick.
I have only had positive reactions. Not one negative.
I have taken some steep hills that I would not have considered even trying before. Great fun.
Once, on arriving home, a visiting friend's bike had been stolen. I went out to look for it. I actually spotted it, pursued and stopped the bike. Made me feel great.
The 24V motor is quite strong.
That's it.
HittheroadJ
152
16
That's it.
HittheroadJ
152
16
20 Months review
I've had the 2 Meerkats for 20 months now.
Wear and vandalism have taken some toll, but they're both working fine.
I've still not had any more punctures than I had after the first month. The bike works very nicely with the Schwalbe Big Apple's I fitted after their first puncture.
After a fall one of the bikes had a slightly bent pedal. I have retained it, but I'll need to replace it at some stage.
I have bought an Izip conversion cit off ebay and re-used the battery and the rear wheel as well as the connector-blocks.
There is some rust on chain, wheel, chain etc.. Nothing troubling.
I've had to replace the brake-pads. They are no longer sold. I resorted to bying slightly bigger pads from ebay and using an angle-grinder to make them fit. The disc brakes are otherwise surprisingly good for normal road use.
I just hope the bikes will last for up to 3 or 4 years with a bit more care, the occasional spare part and maybe a lifepo4 battery.
Still driving. Still happily driving. An e-bike still puts a big smile on my face each time I ride it.
HittheroadJ
152
16
The bikes are 3.5 years old now.
I will need to do them up or merge the best parts into 1 good bike.
The problems have not been down to the bikes so much, more to the occasional bashing.
1. One bike had a badly bent pedal after a fall in the snow. It turns out that the way the pedal is fitted will necessitate replacing the whole part. As it is the pedal can move slightly up/down while driving and that cannot last long.
2. The other bike has had a fall where the front wheel was bent badly. I can still ride it, but it wobbles. The front brake has lost a screw/bolt.
In thee years I have had 3 batteries and I have replaced the batteries inside 1 box once. I'll probably need to get a new battery soon. One of the battery cases has a poor connection with the bike and sometimes cuts out . The current one is noticeably going down. The Big Apple tyres are still good.
I have ridden the bikes less as these problems appeared, but I still enjoy ridingthe ebikes. They are sturdy, carry myself and a full load of shopping (double caliper back, big basket front).
Current verdict/status: I will have to consider whether buying an extra battery and merging the two into one (probably allowing another 1 to 1.5 years). The other option is to dump these bikes and get a new, different, one.
Alternatives? Cyclomatic power plus? otherwise:
1. Powabyke
2. Whoosh
3. Whisper
and many others.
At about £300-£350 per year (total cost of ownership including tyres, etc.) the bikes have given me great fun and an affordable / good value means of (mainly city) transportation.
I would like longer range. Slightly lighter weight and stronger frame (higher carrying load).
I would prefer to keep the low cost (incuded in house insurance, no worries just locking it to a streetlight in town, taking the bike to go out at night). More expensive bikes also come with more hassle and worries
HittheroadJ
152
16
I have bought a Woosh Santana. Better bike in many ways, but the Izips have held their own.
Status with regards to the izips after 4 years.
1. I though the one bike had a damaged crank after a fall (and a visit to a shop). Halfords replaced the pedal for £6. It is now almost as good as it was the day I bought it. Minor points: a. some rust on stand, rims, some parts of the frame. Nothing maor. b. The weight of the batteries meant they could create room from the bashing around while driving. This resulted in them occasionally disconnecting. I fixed this by putting simple plastic strips on the vertical bars through which they slide. Just plastic from a light that can be attached to a steer. Works. c. The brakes th eoriginal disc brakes are still fine, but you cannot by the pads anuymore. I solved this by buying slightly bigger pads and using an angle grinder to cut them down. Replacing the disc-brakes with calipers or new disc with IS-mount and size 160 should be affordable.
2. The second bike had its pedal replaced. It still has a bent luggage carrier. Otherwise fine. Not bad after 4 years.
I may keep one or sell or dump both. As a second electric bike they are great for short distances (shopping, visiting leisure centres etc.).
