Hi thank you for the reply I have ordered these I hope I can work out how to do it thanksThe charger with that connector is extremely rare these days. The charger itself is as common as muck and cheap.
Here's a charger
https://www.ebay.co.uk/itm/24V-2A-Pride-Mobility-XLR-scooter-battery-charger-VRLA-SLA-GEL/263957005070?hash=item3d7510430e:g:JqgAAOSwlgFbqfm~&frcectupt=true
and here's the connector. You only have to find someone that swap the connectors, which is a very simple job if you know how.
https://www.ebay.co.uk/itm/IEC-C13-EURO-MAINS-POWER-IN-LINE-SOCKET-FEMALE-10A-AMP-RATED/200951288646?epid=1423150290&hash=item2ec9a15346:g:LIEAAOSwJr1akaUs&frcectupt=true
One word of warning. Whoever does it must use a meter to check which way round the positive and negatives are on both the battery and the charger cable. Do not go by the colour of the wires because I have seen brown used as negative and blue as positive on many of these chargers - something like half of the ones I've looked at.
The battery connector always uses the outer two pins. The middle pin is left disconnected.[/QUOTE
